6" lift 35s or 37s
JB1
Houston, Texas
I'm on the same fence, 3/6 with 35's or 5/6+2 with 37's.
HolyRam
Cummins 6.7
I'm thinking 5/6+2 with 35's myself
Wise
Wise
Harrison, Ohio
I ordered the 6/3 zone w/35s I really hopefully it will look good. I have the 3.21 and didn't want to re gear with 37.
JB1
Houston, Texas
For 3/6 I would consider a tire size of 325/60R20, depending on manufacturer they are approximately 35.5 x 13.0
Wise
Wise
Harrison, Ohio
Yea I was looking at that same route 315/70/18 didn't know when they could get them though, too late now anyways
JB1
Houston, Texas
Are you installing this yourself or a shop?
I look forward to seeing it finished.
Wise
Wise
Harrison, Ohio
I was going to just don't have the extra time so I'm having a shop do it
Chief_6.7
35's on stock 20's with 1.5 spacers. No rubbing. Also, I'll second the 5" rear coils.
Do you have any more pics of your truck. Say a side shot....... just want to see how far your wheels/tires stick out with the 1.5 adapters. Also truck looks good what's your total setup consist of.
Sorry for the thread jack.
Solid State
2011 Bighorn
Here ya go. Tires stick out about 2.5" past fender. I have a zone 6/5 with bils at 2.1, but just moved them to 2.8 about a week ago.
Solid State
2011 Bighorn
Here
JB1
Houston, Texas
So you have approx 8" front lift now?
post some new pics at 2.8
Solid State
2011 Bighorn
Approximately, yes. Stock front fender was right at 36. After front fenders are 44.5. So, 7.5 lift, and another inch for 35's.
Solid State
2011 Bighorn
And the new wheels stick out about 3"
JB1
Houston, Texas
That looks great, I guess I missed it but what's the new wheel and tire specs?
muddy12
Indiana
I too am getting the itch to go bigger.
Currently have 6" and 35's, and would really like to go a little higher and add 37's the next time I have to buy tires.
However, my truck just barely clears my garage door now, and I sometimes have to park in a parking structure at work. I "might" be able to squeeze a skinny 37 in there without adding more lift, but then I may need extended bump stops to keep the tires off the fenders.
Here's current pic
JB1
Houston, Texas
20x10 Fuel Krank -24, 35x12.5 toyo mt
Thanks
How much is the lift with preload spacer but w/o Bilsteins?.....5.5"
How much without preload spacer?
Trying to calculate this out with my rake
JB1
Houston, Texas
Muddy12.....I hear the Mickey Thompson ATZ P3's run small.
Solid State
2011 Bighorn
Thanks
You dont use the pre loaded spacer if ur using bils. I think that spacers is like 5/8? So, 5.5 would be correct wothout, and ~6" with.
JB1
Houston, Texas
ok thanks, I have searched and read a lot trying to find out how much lift just the top spacer gives in the 6" kit.
2002dodgenvhelp
