8 speed trans tuning
ram1500rsm
Trabuco Canyon, CA
Trying to get the basics wondering if somebody around have HPT experience with the trans. I don't have the 8 speed trans in my truck but my wife 14 Durango SXT AWD is equipped with it. Wife came to me a few weeks ago and asked "Honey, can you change my Durango to shift to 1st gear before coming to a stop ?" Lol i said sure easy peasy, i just need to grab some time :)
First observation is the damn thing has to come to a complete stop before 1st gear is engaged, otherwise the trans remains in 2d gear even when slowing down to about 2-3mph without doing the stop. My 09 Pontiac G8GT was the same and i changed the trans to do a 2-1 downshift at no throttle and about 3-5mph. couldn't be any more easier and should be something easy to fix...
I opened the trans tune today with HPT (i have already written my own tune but never bothered with the trans cause i never done anything with it) and holy macro where is my output shaft speed rpm vs load table ? hahahaha
I'll start with the basics and see how far i can go to do something as silly as to change my 2-1 downshift
"Getting to know your ZF TCM. Sticky please for updates.
The ZF8 is used in many applications and when we originally added it last year, we tried to make it a little more Dodge specific, but quickly realized this was not an easy effort, especially as we add more manufacturers.
The ZF8 is better thought of as its own controller by itself and not a "Dodge" controller, because that's what it really is.
4WD Low are used only during 4WD Low applications, but the Hellcat does not ever use these. The reason you still see the tables is the operating system used by the Hellcat is not unique to the Hellcat, other applications that do have 4WD Low (the trucks) also have the same operating system. Because we define things by operating system, you'll see them in all applications, including unused ones.
Normal, Perf, Sport, Max: these are shift strategies. Which one is used by which mode is actually quite a cluster and we don't have an easy way to show which is which, so its being added as a loggable parameter in Beta, under "Clutch Shift Type". For example, on a Hellcat, Normal trans mode in Drive, uses "Normal". But put it into Manual Mode with Normal Trans still selected, and now it uses Perf tables.
It's also considered a "use the highest below this". For example, if your current type is Sport, but the table set only has Normal and Perf, it uses Perf. The idea being that Normal -> Perf -> Sport -> Max have increasing levels of shift speed and feedback.
As to the "Normal, Normal Perf, Sport, Sport Perf, Track" shift schedules, I've started to relabel some of this to better correspond to whats happening. Basically depending on your actual selected trans mode, how aggressive you're currently driving, and your perceived hill grade, the shift tables are designed to get more or less aggressive.
To explain this, I'll use the ZF9 as an example as I believe we will move everything to be more like it to better indicate this.
Attachment 81473
First, we decide our Aggression level. To do this, we need to know our current Shift Situation (which is basically your trans shift mode. In the Hellcat, Normal, Sport, Track, Valet, etc all have their own "situation"). This is loggable.
The situation automatically puts you into a certain range of "Driver Type". 0 being the least aggressive driver, up to a max of 14 being the most aggressive driver.
As well, there's a constant "counter" running thats basically an indication of the current aggression of your actions. Some situations may have a range, for example, 20 to 200 for your aggression counter. As you move up the counter, you start moving into higher driver types.
Finally, your driver type is mapped into an "Aggression". For example, we have lower type = 0, upper type = 4, lower aggression = 0, upper aggression = 1, this means that driver type 0 is aggression 0, driver type 4 is aggression 1. In between driver types are blended between the various aggressions.
For Dodge, we simply named the aggression modes. Normal = 0, Normal Perf = 1, Sport = 2, Sport Perf = 3, Track = 4. However, the Shift Pattern Aggression Mapping for the Hellcat actually has the highest aggression being 3, Sport Perf. I.e. the high part of the table for driver types 9-14 actually blends from 4 to 3 aggression.
Now once you know your aggression, you'll notice there are 5 tables for that given aggression. These correspond to your accel factor / hill grade essentially. On the ZF9, its labelled by the Shift ID youd see if you logged Shift ID, on the ZF8 we still have it labeled "Normal 0, Normal 1, Normal 2, etc."
Attachment 81474
But, by using the "Accel Factor" tables, you can see what your final factor will be. Unfortunately this isnt straight forward to describe as the inputs are based on measured G-Forces, estimated road grade, etc. But the gist is Accel Factor 0 is typically when you're going downhill, Accel Factor 1 is normal, 2,3,4 are proceeding amounts of aggression (heavy Gs) or uphill orientation. You can log Accel Factor directly as well to help actually know what you're currently in!
These are the standard, aggression based maps. As well, the ZF8/9 have 75 MORE maps for various other conditions, though usually not all of them are used. I've placed these in a non-aggression section, and it corresponds to stuff like Cruise Control, Rock Crawl modes, and so on. Which ID is used by the logic depends on what you're doing (Cruise Control), shift situation, accel factor, etc. It all depends on what that type is used for.
Attachment 81475
For example, if you have cruise control active with accel factor 1, this particular setup will use Shift Pattern/ID 35 no matter what shift situation you're in.
BUT WAIT, THERE'S MORE.
Even once you know this final shift pattern ID, it can be remapped into another ID entirely by one final table. On the ZF8 we tried to show this with a bunch of comboboxes, but ZF9 and moving forward we'll just show the raw table.
Attachment 81476
For our example, Cruise Control, Accel Factor 1, we desired pattern 35. However, this final step maps Pattern 35 to Pattern 67. Pattern 35 is never even used!
I wish I could tell you this is easy or straightforward, but its not. It's a lot to swallow and understand. Transmissions are getting easily as complex as engine controllers, and the ZF especially so because its designed to be used in so many different applications by different OEMs. Because of this insane amount of configurability for the OEMs, the actual mapping itself is equally as configurable.
Hopefully if you read through this a few times and try to follow along with your calibration, you can start to understand it a little. If you have more questions, just ask, I'll try to answer them as I can!"
I'll start doing some logging today today what shift strategies are in place here.
the SXT doesn't have sport or performance mode, we only have an ECO mode switch, and i have to press it to disable ECO mode every single time. Should be easy right compared to the R/T or SRT8 :)
Attachment 81473
Attachment 81474
Attachment 81475
Attachment 81476
Just be careful as you can cook the 8 speed in short order with a poor tune. Jeremy Satera does the majority of Paramounts tranny tunes,if he'll give you any advice or tips is another question though,as the majority of tuners keep their knowledge to themselves
6.7CumminsDrvr
The Dude abides………
Georgia
They didn’t always do this.......IIRC FCA made an update for the trans to not shift to first until stopped or barely moving from all the folks complaining about the harsh bump they were experiencing while coming to a stop.....
I have found that if I slow down enough but just keep moving with the drivetrain unloaded I’ll get my truck to slip into first without coming to a complete stop, and boy does she pull nicely when I hit the gas :)
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Attachment 81473
Attachment 81474
Attachment 81475
Attachment 81476
Excellent info! I need to get a tuning license so I can play with this stuff in my downtime.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
I was reading about that TSB. The Durango has to be fully stopped for it to engage 1st gear, damn it even slowing down to 1 mpg won't force it to shift to 1st :) crazy.
I have logged some of the shift chit. You can see commanded gear is 2nd, even at 1mph, trans output rpm is 48rpm, shift situation 0, shift trans mode 0 (this seems to be normal, Eco on = 512 which i still don't know what it maps to in the trans tables)
I may need to download the Beta, i'm running the latest production version 4.8.7 and i don't see the clutch shift PID
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Got it done. I spent some time this morning reviewing the tables in the shift scheduling section trying to make a little more sense out of them.
Dont know if i got the interpretation on the tables correctly or not, I posted the question in HPTuners and i'm still waiting for more details. Tunning the ZF8 8 speed seems to be the best kept secret.. :)
I needed to find the Shift situation table, and i believe is has to be the one called Manual in this print screen. TCM-30001, Shift pattern manual control mapping.
I can correlate the shift situation in my logs, which is basically 0 for Eco-on Disabled, and 2 for Eco-on
With the shift situation ID i can map the shift pattern, which technically will be shift pattern 27 for both situations in my case. I'd think in the RAM 1500 will be different
Asides from shift pattern 27
The aggression / non aggression tables seem to indicate more or less a shift pattern in play as well, and the shift pattern tables are basically where you indicate the trans output shaft rpm that intructs the TCM where to shift. Again, i'm a rookie with this transmission so proceed always using common sense.
You can see from the print screen above the green tables i changed (they're green because i'm showing where the changes are from my stock tune with respect of the one i loaded up today in my calibration)
So to fix my wife 2-1 downshift i simply used 150rpm output shaft speed, all the tables below had 7 rpm before
I changed:
Normal 0, 1 and 2 tables which in turn also changed aggression 0, 5 and 10 (VCM Editor did the aggression ones for me, don't know how they're correlated to each other but once i changed the normal table, the editor changed the corresponding aggression one for me)
Then Shift pattern 27 and 43, 42,44 and 45 had already values above 100rpm so i didn't change them)
once i change 27 and 43 VCM editor changed Eco1 and TUTD/Paddle for me, see the highlighted green tables
after making the changes i saved the file, loaded the tune in my PCM/TCM and took the Durango for a spin.
The result she now makes a 2-1 downshift at around 3-4mph when slowing down with the output shaft RPM falling below 150rpm
Again i only used 150rpm where the 7rpm values were located before in all those tables pretty much still following the factory approach.
Before:
I had to be fully stopped for the trans to go in 1st gear basically from a coastdown situation.
Now she does the 2-1 downshift once the output shaft rpm have fallen below 150rpm, which can be around 3-4mph. Shift is not abrupt and makes a nice difference to be in 1st gear when you give her gas after slowing to about that speed from a slow corner where you have to look left and right before making your right turn for example and you didn't do a full stop.
Hope it helps somebody.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
I changed:
Before:
Thank you for the info!
Curious. How does the durango react to the 2-1 shift?
So basically you could go through and remap the entire transmission based on edits and driving style. Oh and 75 maps :eek::D
I will try my hand at this soon!
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
it shift super nice you wouldn't feel a thing, no hiccups, no jerkiness, super smooth.
and yes pretty much. I only changed the tables for the 2-1 shift i can see with the 2 modes available on the trim i have , but you can remap the entire thing if you want. you'll have to find the shift strategies in use by your model year truck using that manual table i posted along with the driving modes. Should be easy as i don't think RAMs have Sport mode, Track mode or none of that, but we have towh/haul, normal is normal ofr the most part, i don't think you have to change any of the Eco patterns cause most likely your truck won't have an Eco mode ? Prob a little more invloved if you're changing WOT shift points as you'll find to find the aggression modes in use etc.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Right. All the ZF8 speeds have adaptive learning. So I know I'll be in the aggression maps right out the gate.
Makes me laugh because those who complain of the stock shifting never consider their driving style as the problem. Always the vehicle. :confused::confused:
noraa73
