JayDizzle
JayDizzle, my brother..... See this post I created recently after recently purchasing a 2021 Ram 1500 Classic.....
2021 Ram 1500 Classic 5.7 / ZF8 — Low-speed moan/resonance around 1,400 RPM after upshifts. Normal?
I have a 2021 Ram 1500 Classic Tradesman 5.7 Hemi with the ZF 8-speed, around 141k miles. The transmission shifts great... no clunks, slipping, harsh shifts, delayed engagement, flare, or shudder. Honestly, it shifts so well that I’d imagine a new ZF8 would feel about the same. The only thing...www.ramforum.com
Took it to the dealership. I mentioned that it appeared to be some exhaust resonance noise and pointed at a couple things for him to check out while it was on the lift. He drove it around and then when I got there later it was still on the lift.... he took a screwdriver and tapped the exhaust pipe from front to back.... and at some point there's approx. a 3 ft. section of pipe that has some internal baffle that makes a VERY similar noise. Since you've replaced all these things.... if you REALLY want to get rid of the noise.... tap your exhaust pipe and you'll more than likely here the same "note" when you get to a certain part of the pipe that has an internal baffle. I'm about 99% sure that replacing this pipe is going to get rid of our 1.4k RPM "vibration" noise.
I mean it has to be something stupid like that. At this point, I’ve replaced the entire dang driveline & it still does it.
I’ll get under there & poke around at it. Let me know if you do anything & I’ll do the same. I still watch this thread. And thank you, btw!
