91 fuel pump and asd and other relays
fester_1
IL
get right to it. i use hayes 4b-4 page and it states on tbi system i have 4 relays on fender. i seem to be missing the part throttle unlock relay. i have a 91 dodge ram250 truck , coil mounted on firewall btw. is this optional relay?
2. fuel pump mysteriously quit over winter just sitting, tested 83159 asd relay and have 12v on 30 red wire, 12 v on 2 blue 86 wire , 87a is cropped off at factory, 87 is green black and 85 blue yellow, i got 90 ohms on relay coil 86-85,good, and 30-87 is normally open and that was good. i also bench tested relay and it was good. is their a fuel pump relay and if so where. the 4b-4 page shows a fuel injected system also and it is in the row of relays for that engine.
3. their is 3 connectors under the hood hinge that arent used a 2 wire green/brown and 2 black , a L shape connector 2 blue,black/white,green,and pink wires, and then one identical to asd at 87 blue/white.30 blue,86 2 blue,85 2 orange/black is this fuel pump relay or part throttle unlock relay or just a test port.
4 fuel pump itself 4 wire connector green/black,blue/yellow,2 white that go to 1 white spliced, i assume the white is ground. it looks like green/black goes to orange wire on pump and 1 of the whites goes to black wire on the pump. the blue/yellow and other white wire goes to sending unit. so if i put 12v to green wire and ground white wire pump should come on. I have removed pump already.would like to bench test it to see if i messed it up with jumper wires.
F
fester_1
IL
apperently i dont have this part throttle solenoid on tranny or a lockup torque converter. whatever that means lockup torque converter
F
fester_1
IL
the pcm provides ground for the fuel system. so i had to ground pin 85 of asd relay to fender to get relay to supply voltage to fuel pump ,ignition coil. Still not getting ground to tbi injectors so now i will ground the tan and white/green wire so the injectors will open. bought new fuel pump and can hear it running but injectors wont open. hopefully that is the last corrupted ground in fuel system. truck starts by pouring gas in top of carb.
F
fester_1
IL
this was wrong about grounding this pin
Fatboy1989
