93 octane?????
09SMOKINHEMI
TEXAS
I can't find any gas station in Amarillo, TX that has 93 octane. I want to be able to tune my truck with the 93 tune, but not if I can't fill it up with 93. Any options? should I buy a case of octane booster and use a bottle at each fill up?
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
That's weird Amarillo doesn't have it. If I ever go on a road trip in my truck I'm gonna lower the tune. It seems a lot of places don't carry 93.
quietpeen
2021 TRX
Hellcat
i've noticed where i have lived that 93 is hit or miss with stations
09SMOKINHEMI
09SMOKINHEMI
TEXAS
yeah, the highest I've found is 91.... when I've gone to Houston, it seems like every pump had 93
BlackedOutHemi
DFW, Texas
2012 & 2012
Every pump here in dfw that I've been to has 93. Although when I went to Abilene the highest was 91.
the codes
Houston, Tx
Magnum 5.2
in Houston it's hard to find a gas station that doesn't have 93 lol sorry your having that prob. Iv noticed chevron and shell have 93 more often than any other place
09SMOKINHEMI
09SMOKINHEMI
TEXAS
Well I'm currently running the 91 tune, but I'd like to be able to run the 93 since its available
Sent from my DROIDX
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
my yukon was tuned for 93 by Black Bear, used 91 in it daily...no 93 around here either.
LoadedLaramie
Columbus, IN
running a under octane fuel in a tuned vehicle will cause detonation and can fry your plugs and rings over time.
i always go to the same station here and they only have 87 and 93. currently running 87 tune and im going to switch back and change my tune higher to regain some of this horrible mileage from winter gas.
09SMOKINHEMI
09SMOKINHEMI
TEXAS
Is there anything i can do to boost octane? Didn't know if octane booster was just a scam
Sent from my DROIDX
the codes
Houston, Tx
Magnum 5.2
idk how diablosport tuners are, but I know the guy who I got my SCT from (HemiFever), he programmed the tunes so that 91 could be run with the 93 tune since people fall into the situation your in.
09SMOKINHEMI
09SMOKINHEMI
TEXAS
that would be sweet if I could do that with the diablosport
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Timing on the performance tune is to much to run lower oc then called for. Codes im willing to bet Sean took a few degrees of timing out for your tune on the SCT.
Graygoose
Oklahoma
Convert, for now.
small
Not with a computer controlled vehicle. You have knock sensors that detect knock, or preignition ( detonation) and it will pull timing out. Now you do have wasted power, more timing pulled is like torque management. But as long as you have good knock sensors, it will pull timing if running 91 on a 93 tune. So no worries of detonation.
Graygoose
Oklahoma
Convert, for now.
small
Sent from my DROIDX
it works, but dont see the 'need' unless your going out street racing, etc...surely wouldnt do it daily.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
In a perfect world yes it will pull timing to save the motor. Have you seen the top ringland of the stock 5.7 pistons? There is no room for error and only takes once to crack the ringland. It is advised by every tuner to use the correct fuel for the correct tune.
crcraft
