94 1500 5.2 no acceleration on rpms
Michael barnette
Arkansas
I have a strange issue as my 5.2 idles fine but when accelerator pedal is pushed starts backfiring and loosing rpms til it dies if you hold the pedal down. Can’t get over 2000 rpm. Any help is appreciated.
muddy12
Indiana
Does it still have factory catalytic converter?
I had a 93YJ that did the same thing when the cat became plugged.
KeepRight
ExFalconFxr
US
EcoDiesel
Let's maybe go down a short list. Does it throw a code?
Cat converter clogged
Clogged/Bad fuel injectors
Clogged/Bad fuel filter
O2 sensors
Bad or loose throttle control connection
Doubtful - needs tune up... Plugs, wires, etc.
Holler if I can help...
M
Michael barnette
Arkansas
It has the obd1 setup and I can’t retrieve codes. Truck idles great- no missing or rough idle. I just bought the truck and it ran good when I first got it but now won’t go over 2000 rpms. I’m going to try a fuel pump and if that doesn’t work I’ll be lost as someone changed the exhaust system and it has the upstream o2 sensor but not the downstream one. Runs good when first starts but can’t accelerate after a couple of minutes running.
JohnnyMac
SouthWest Washington
2018 1500 Laramie
3.0 EcoBurner
I agree with the other folks. If those don't work, I believe you can unplug the upstream O2 sensor and if it runs better, then it's a sensor issue. Another problem may be the Throttle position sensor. Those can cause lots of problems with timing, air/fuel mixture, etc. If it is causing the truck to run too rich, that can not only make the truck run like crap but can ruin your catalytic converter too. May have multiple problems. I would also pull the cap/rotor and make sure the contacts don't have a bunch of buildup.
Good luck and let us know what you figure out.
KeepRight
ExFalconFxr
US
EcoDiesel
Fuel pump is definitely on the list... But one of the most expensive. I'd prob look into the fuel filter first; can't hurt ya know.
That too the o2 sensors... Way too much money. You might swap o2 sensors around... I know, that's prob waste of time. Those damn things were over $100.00 each for my older suburban.
Not sure why you can't pull codes. Swing on over, you can borrow my older scanner.... Does it have a check engine light? You can count the flashes...
Again, holler, I'll help the best that I can.
muddy12
Indiana
Since it’s OBD I, there should be an on/off sequence that you can cycle the key, which will cause the check engine light to flash/blink the code. That’s what I had to do with my 93, as it was OBDI as well, and did not have anywhere to plug in a scanner.
Just FYI. OBD II (as well as the standardized diagnostic plug) didn’t start until 1996.
Also, if I remember correctly, the only fuel filter on the second gen’s, is the sock on the end of the fuel pickup, which is attached to the fuel pump located in the tank. You have to either drop the tank, or pull the bed.
muddy12
Indiana
Was the catalytic convertor removed as well, or does it still have one?
M
Michael barnette
Arkansas
Still has the converter but it looks like someone cut out the pipe past the converter or the downstream o2 sensor and put in a piece of pipe the join the exhaust together
muddy12
Indiana
Unless the converter has been gutted, my money is on the cat being plugged.
M
Michael barnette
Arkansas
It was the fuel pump- it runs fine now. Thanks for the help. Now on to the slow shift issue and frontend looseness
Joey93
