DanKScott
Hello, I have been chasing a misfire issue for the better part of a year now and have no idea whats going on. I have a 96 1500 with the gas 360 in it. I have replaced plugs, wires, cap, rotor, injectors and ive even went in and done timing chain and sprockets. Done compression tests lowest I had was 115 which from all my research is perfectly fine. Biggest annoyance is the fact that I have no actual check engine light on about it. You can see and feel the entire truck jump at idle when it misfires. Then it gets pretty bad at about 35-40. Im just at a loss. I know theres a bunch of vacuum lines as well i just dont know where to start with that. Any help would be greatly appreciated. Thanks, Dan
