97 3500 - what discs will fit?
HowardNYFarrier
UpState NY
Just picked up a 97 chassis cab, drove well, but on further looking found it has no rear brakes! Did check out frame etc, saw rotors but didn't notice calipers were missing - too much else to look at.
Build sheet off of vin says drums originally. Got caught bad on this deal - trying to salvage without breaking bank too much further.
Need to locate info on appropriate calipers or how to identify rotors (year) for replacement.
Nick_rp
I=V/R
puyallup, wa
5.7 Sport
99% sure you might be out of luck for a stamp on the rotors that could help.
Theres are a few ways conversions are done.
-used rear diff from newer model with discs
-3rd party kits
Check the rear axle number stamp and see its the correct model for your truck. If it is, then a 3rd party kit was probably used.
You might be better off just buying a new kit since the calipers have been gone for im guessing awhile. You should also replace the brake fluid
