A + and - ?
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
2015 Quad Cab 8 speed transmission V6
On the column as you know the + and - for the trans. I assume that you hit the - to stay in a lower gear. IE: hauling a big load etc ? Does it reset each time you restart the truck? Or push + and adjust ? I also assume a light will come on in the dash! I know it is a Noob lame question but before I try something new I like to know the proper way!
I did finally get to use my 4 wheel drive today for the FIRST time :) And I can say WOW the difference on a snowy/icey road was night and day!
Thanks for answering my noob question even it is to just suck a egg lol
shane1981
millington tn
it will reset when you put it in park and it will display which gear its in
tuned by Jay Greene
The buttons only limits the highest gear the transmission will shift into. The + button will not force an upshift.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thanks for answering my questions!
MADDOG
Living in a Firepit
6.4L HEMI
I'm not sure this is the same with an 8spd but my 6spd will upshift to any gear from the previously set gear if I push the + button.
What I mean is if I am in manual mode, using the buttons, and am in third gear (indicated) doing 45MPH and push the + button, the transmission will upshift to 4th gear. If I press and hold it, it goes all the way to "D" which is full auto.
The reverse process works as well. If I am in 4th gear indicated and doing 45MPH, then press the - button, the transmission will downshift into 3rd.
So have you tried shifting up and down using the button yet?
DannyMK2
Long Island, NY
2015 Power Wagon
to clarify this, you cannot force an upshift by pressing the + button. all your doing is selecting the next highest gear the transmission can shift to. if other parameters for the transmission to shift have been met, the transmission will shift. you can force a downshift though.
clh1220
st Louis
That is correct.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
So far I have not used the +/- as I have not towed anything yet , I just like to know the whats and whys on anything I try so I do not damage anything,,I tend to run on the side of caution lol
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thanks everyone for your input on my Noob ? I got the info I was looking for :)
MADDOG
Living in a Firepit
6.4L HEMI
true but in my experience, if you run the RPM's up like I do, it will shift right away.
That's why I run it in manual mode! :naughty:
joshhhh
