I was at a dealership in Texas and asked them if they had experienced any similar issues w/ rams, they told me to check under the fuse box where the wiring harness attaches to the fuse block, the connector that the fan fuse plugs into have been getting hot, melting, and causing a lose in connection that was intermittent.
When I got home I pulled the cover off the box, unclipped the 4 tabs that holds the fuse block in place, lifted it up until I could see the wiring harness connectors, and got cold feet.
I had to take an extended trip in the next few days, so I was afraid I would screw something up so I did not unclip the wiring harness.
However when I was putting the fuse block back in I was pressing down on it to reattach it and I pressed on the actual fuse ( im not sure if it is a fuse or called something else) it was in the spot marked on the lid as (fan) and I was able to press it into its holes a little further, as if it was slightly pulled out, and it clicked. I didn't think much of it until I went on a 2400 mi trip, it has not quit working since.
sorry this is so long, In Short, push down on your fuse and see if it is loose or causes a connection issue.
