A/C trouble
SpecialEd97
Commerce Ga
5.9 cummins
I'm having trouble with my A/C it's blowing cold air, but will only come out of the defrost and floor vents. Any ideas what the problem is started yesterday. Was working great then I stopped at the store and then the problem started. It will run on the reg a/c setting until you run the fan on high.
bassslayer25
East, Kansas
5.9 360 V8
Check your vacuum lines. Not sure if thats your problem but its a good way to start.
amocoharley
That could be a door problem. Broken or not opening.
