A couple of lowered questions...
Noob2Trucks
I'm rubbing sometimes in the front. I still have the stock wheels and tires. I'm thinking a slightly lower profile tire would fix this? Once these wear out, I'm planning on getting a new set of wheels (20 or 22), but I figure the overall diameter will be shorter. Am I on the right track?
I've bottomed out once or twice in the rear. I still have the bump stop cups so I'm thinking they have to go and I can get some belltech shorter ones?
I've also got a set of helper bags, but I'm not sure that'll help with the issue as I don't tow.
Finally, does anyone know the stock height front and back for the 2wd RCSB? Can't find it and people have asked how low I went, can't tell them, lol. Supposedly the kit was 3/5.
Dragonsteel
MIssouri
My RCSB is on a 2/4 drop with 285/45/R22 tires mounted on 22 x 9.5 wheels and I do not have any rubbing issues. Stock 275/60R20's are 33" tall and the 285/45/R22's are an inch shorter in height. Rear bump stop cups need to be removed.
1SloRam
Ms
2/4 belltech w/ Inez relocation brackets on 275/55r20’s
Only rubbed at full lock, rear bottomed out once. what kit was supposedly 3/5?
MCMLXIX
Las Vegas
5.7 HEMI R/T
I couldn't find a 3/5 kit so I have been collecting parts to get there. Crown Suspension front springs and Timber Grove rear bags to replace the OEM rear coil springs. I have 305/45R22 on 22x9.5 ET20 wheels, overall diameter is 32.8"
The picture in my signature is stock height... hope to have the drop installed next month
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Inez sells a 3/5 kit for $1200.
The photo of your truck looks like 2/4 or 3/5.
I have 285 45 22 no rub any time. I'm 2/3
I'm mounting 275 60 20s on a set of chrome clads on Saturday to run thru the summer while I refinish the 22s and mount new rubber. I don't anticipate problems
Noob2Trucks
Noob2Trucks
Thanks everyone. I think once I get new wheels/tires, it'll take care of whatever rubbing in the front I'm dealing with.
I'll get the bump stop cups cut in the rear.
The kit is the Inez kit. I think it's just the 4/6 kit with some shock isolators thrown in the loft the front a bit.
I'm still looking to know the stock height from the top of the wheel well (front & back), if anyone knows.
Thanks again everyone!
Noob2Trucks
Noob2Trucks
Any pics on the 22s? Sounds like what I need.
Tray Burge
On the porch
Love the truck!
Although mine's a different year and suspension set-up, I had the exact same issue up front when I lowered mine and hit dips in the road, 22" here also.
I put on performance shocks and it completely fixed my intermittent rubbing in dips on the front.
Desertwolf
