a little touch up.
ljvsnyder
s. Illinois
Doing some touch up work from a hit-n-run accident, decided to break out the plastidip and painted the grille and front emblem as well.
[/IMG]
took a little time to add a shorty antenna as well.
[/IMG]
quietpeen
2021 TRX
Hellcat
nice work
OneShot201
2012 1500 Express - Mineral Gray
Yeah looks good.
You should plastidip the base around the antenna as well maybe, to black it out completely.
Thumbs Up!
ljvsnyder
ljvsnyder
s. Illinois
yeah, the antenna base started looking like that pretty early on. going to see if chrysler will warranty it. I have hit it with enough armor all that it shouldn't be turning colors.
NotJesus
That's what armor all does!
Musclemckeester
Houston, TX
n/a
n/a
I sanded down my antenna base and painted it to match my truck. That's an alternative if you don't want to go the plasti-dip route.
ljvsnyder
ljvsnyder
s. Illinois
thanks everyone for the comments. I also through a clear coat on the emblem which gives it a bit of shine. Also takes away the plastic/rubbery feel that you get with plasti dip. I am thinking about trying to mix up some plasti dip that is close to matching the mineral grey bumpers and to the horizontal slats on the grill. Right no it is kind of just plain. Would love to do RC grill inserts that leaves the center bar, don't want to loose the ram head. Going to buy a new rear emblem and try to do the same on the back. Don't want to remove the rear until I know it comes apart like the front.
quietpeen
2021 TRX
Hellcat
from what i have read, the rear does not come apart
ljvsnyder
ljvsnyder
s. Illinois
That makes doing the changes hard, not impossible. If not could always reverse the look and do mineral grey ram head with black background. A little bleach should remove the chrome coating.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I know my back emblem came apart. But it's not as easy. It was plastic welded in a couple spots.
ljvsnyder
ljvsnyder
s. Illinois
How does the antenna base come off. I am thinking painting it is the best route. Tried several restore kits and nothing has worked.
ljvsnyder
ljvsnyder
s. Illinois
Well, decided to change my emblem colors. Went with MG ram head and pxr back plate.287900[/ATTACH]"]IMG_20120821_145746.jpg
287902[/ATTACH]"]IMG_20120821_145257.jpg
ljvsnyder
ljvsnyder
s. Illinois
Thanks, took several coats of paint, and has 8 coats of clear. If it flakes like the last color scheme it Will be custom billet badges. Starting on a rear emblem. Got it scuffed and primed, now i have to get it masked to do the two tone color to match.
Fuguuvhitch
