A Running board and Mud Flap ? :O
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Tried to install the OEM Mud Flaps with the OEM Wheel to Wheel boards ! Rear fine and as many have mentioned the front does not fit like they should :O
SO the question of the day has anyone install the OEM flat type or after market flat type with OEM Boards ? They look like they will fit but I have a front set that doesn't work now and do not need more hanging around lol If so I will be posting up my set up F/S soon
Thanks for any help
I have the Husky Liner molded mudflaps(similar to the Ram ones) and the OEM wheel to wheel running boards, they fit with no problems. There is about 1/4" gap between the two. I do have the factory fender flares also.
Ram_Fish1
Indiana
2013 BigHorn CC 4x4
5.7L
same issue so I threw on the weathertech no drill flaps p/n 110026, with my Oem wheel to wheel boards. Plenty of room and I like the slimmer look better than Oem. Followed body lines nicely. I have factory flares if you do not your p/n will be different
I only did fronts on mine
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
No flares on mine so that may be part of the issue! My molded RAM Flap which I like better then the flat one mounts OK wheel well holes BUT the screw hole on the bottom does not line up because the boards push it out :O Guess I will try the flay one
Thanks for the replies
Ram_Fish1
Indiana
2013 BigHorn CC 4x4
5.7L
That is actually odd to me, because I had the Oem molded flaps before I added the factory flares. They touched the step but still fit
alphaprojects
