? about gears
bigtigga84
dela....where?
gonna do 4:56's some time soon. bought a used set for the rear off another forum and they never did answer my question. trucks 4x4, set i bought for the rear has approx 20k miles on them. is it gonna hurt to put a new set up front?
pinion off "used" set
ring off "used" set
Bad Habit
Land O Lakes
Modded 4.7l
you'll be fine...i got my 4.56 motives off a guy on dt for 225 shipped, they were brand new never installed, i still have my 3.92 75k if anyone is interested...
Deviate
St. Augustine, FL
2005 4x2
Dammit Jay! I was just browsing around here and saw your avatar and now I've wasted 20 minutes just staring at it! What were talking about again?
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
those gears look to be in very good shape for being used. looks like they were installed correctly as well.
Bad Habit
Land O Lakes
Modded 4.7l
used gears dont have a break in procedure cause they are already broke in...the new ones do....i'd put the used up front and the new in the back so you can break them in properly, you will be using the rear more than the front of course....
bigtigga84
bigtigga84
dela....where?
had to look up how much they were, lol. had em for a couple months i forgot. they were 100.00 shipped. cool thanks guys.
bigtigga84
bigtigga84
dela....where?
hmm, never thought about that. does the front still turn when 4x4 not engaged? and does the break in for the front require 4x4 to be engaged?
bigtigga84
bigtigga84
dela....where?
damn, didn't read your hole post before i replied. the rear gears will fit up front? thought they were different sizes just same ratio?
Marx
Southeastern Ontario Canada
Hemi 5.7L, 345 ci MDS
I was just saying basically he can't give'er after he installs the gears because he has to break in the front ones
guess i could have worded it differently
3rdStrikePerformance
Sikeston, MO
Be hard to do since they are two different axles....
NO, they are not the same. They are not the same axle, nor do they turn the same direction.
Sikeston, MO
The front axles turn constantly, but they are not engaged with the differential when it is not in 4wd, therefore your gears will not wear as much.
bigtigga84
bigtigga84
dela....where?
didn't think they were interchangeable. thanks duane, and everybody for the responses........... I LOVE YOU GUYS!!!! :3639243774_5f528137 i swear, just like this forum so much better than the others.
