gnslngr
I've searched several times to try to find my problem with no help. So here is another brake issue.
I have an 2002 5.9 Diesel 2500 4x4 with 4 wheel ABS.
My ABS and brake light is on. Changed front pads. Changed the front left wheel bearing and of course hooked up the sensor. I still have the ABS/ brake light on. I checked my speed sensor on the diff and it shows 1.8 Ohms. My speedo works fine. I had Oreillys scan it and got a code "25" which is left front signal erratic and left front signal circuit malfunction. So I'm thinking my issues is from where I plugged in the new sensor up to the module because I had the lights on before I changed the bearing and sensor. If I turn the truck on (not running) all the lights come on then go off but then the ABS/brake lights come right back on. We cleared the codes and as soon as I got any worthy speed up the lights come right back on....PLEASE help!! Thank you very much!!
