ABS blinking and chiming
Ben Murrie
North Carolina
V8
Hey All, was hoping to get some help from experienced voices. I've got a 2002 RAM 1500. The ABS light constantly flashes and dings throughout all trips. If I take the fuse out, the dinging and flashing stop, but I get a consistent ABS/Brake light displayed. The ABS system seems to work fine, and all the brakes/rotors are new within the year. Per advice on this forum, I have also replaced the rear speed sensor, cleaned out the rear differential, and made sure the brake fluid was good. Any other thoughts as to what's causing this? Thanks
srlewis1
St Louis
Did you ever get your ABS problem solved... mine is doing the exact same thing
shanmccarthy
