ABS Control Module Replace C2200
TreyL
I have a 2013 Ram 1500 5.7 Hemi. About a year ago I got the c2200 error code for an internal failure of the abs module. After about a year of waiting I finally found a replacement part. I installed the new module and ran the abs initialization process on Alfaobd. The problem is it would fail the run clearing rolls information step. I’m not sure if this is related to the problem I’m experiencing but now the all other lights on the dash are gone except for the abs light. It flashes and dings constantly (every 2-3 seconds) while the truck is on. Once the truck is turned off, it will not fully turn the inside gauge cluster lights off. It bounces back on when it’s getting close to shutting off. The same time the bounce happens, there is ping noise coming from the actual abs module / pump. The only way I’ve found to get this to stop is to disconnect the battery or to pull fuse f26. Traction control, cruise control and abs appear to working normally while driving as far as I can tell.
I’m not sure what to do from here. Please help!
Jerseybob175
Nj
TreyL, I am in the same situation you are with my 2017 crew 5.7 1500. thanks for the F26 fuse. I am currently looking for the ABS module and have found some offers from $350 - $500.
StephenC
SC
5.7L
Same here TreyL, I feel your pain. I too have a 2013 RAM 1500 5.7, and I too have been waiting for over a year. I found a refurbished module for about $525 + $75 core charge, but have already spent $300 over two years ago for the dealer just to identify the part malfunctioning. I just starting to familiarize myself with what will be involved with reprogramming, and so far that seems dicey.
joshhhh
