MoparMagic'00
Hey Guys I have a '00 1500 5.2 auto 4x4 with rwal (rear wheel anti-lock) only and Ive had an ABS+Brake lights on since ive owned it (2 years) ive changed the rear abs sensor on the rear end with no help.. My speedo works fine (maybe a hair off but i am running slightly larger tires) and the cruise works fine.... so im lost.. CODES: codes are the p7202? I believe it says low voltage speed sensor output... and some O2 codes... the only other code i have is a random misfire on #3 that im still trying to figure out
ANY help would be greatly appreciated...
