abs keeps running
hemi1500
hemi
I got at 04 1500 w a hemi. When I parked my trk n shut the key off the abs pump keeps running. Does anyone have an idea where to look to fix this. I appreciate any help thanks
HemiBabe
DFW
Welcome to RF.
With a quick search I found this:
There is an ABS fuse, try pulling the fuse to save your battery - and you can also try to change the relay to solve the problem. (which is not as expensive as having to buy a pump)
You will probably be better off by replacing the ABS control module and then do a hard reset
SmokedRam
Zephyrhills, Florida
Definitely pull the relay and check it...not all that unusual for them to get stuck open and cause things to run. Use to happen with my old S10 too, the damn fuel pump relay would stick open, causing the fuel pump to run with the ignition off.
