abs modular
2008dodgeram2500
i have a 2008 dodge ram 2500 3/4 ton i have replaced all the wheel sensors, sent my abs module out said its unrepairable so i bought 1 from ebay and the part number P55366224AN is exactly as mine but the TDMBK is different the mine will this be a problem. does it need to be reprogrammed, if so can i use my tuner that is a diablo to reprogram. disconnected battery, also cruise control dosen't work. i have a p0734 think thats the code i know its a incorrect 4th gear ratio think thats because abs modular is bad
Core-Lokt
2005 Ram 2500 4X4 ST
5.7L
I'm clueless about this. I PM'ed you.
mikep345
