Adding horn without removing OEM horn?
Ramster96
5.2L
I would like to wire in another horn without removing the oem horn. I can't seem to even locate the original horn? Are there any videos showing how to do this on 1996 Ram 1500? Thank you for any videos or help!
crazykid1994
Stock horn is in the bumper driver side mount if i remember correctly. If you are trying to add a second horn you could add a push button and relay and wire the new horn up to a relay.
R
Ramster96
5.2L
If I could locate the two wires going to the OEM horn I could just cut them and add new horn but I can't find the two wires must less locate the horn. It must be hidden somewhere inaccessible???
With the 2013 & newer Ram truck steering wheel horn pad, there is no easy way to just give the horn a quick little Herbie type beep
There is a delay built into the horn & instead of a quick beep to say hello, the horn blares & you make people jump.
The '96 horn is part of the drivers side fog light assembly
