Adding projectors to my '13
Exhausted
Edmond, OK
I have a 2013 with quad headlights that have your HID set up
If I add projectors and the harness to make it work will I still need the one with two resistors (one for hyper flash and one for bulb out) and the one in my HID harness
Or since I already have one in the HID harness (for the bulb out) I just need one more on each side for the projector harness
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
The projectors and the adapters to make those fit are a different setup from the HIDs, so you'll need the '13+ ones and that will need 2 more resistors for those boogers.
E
Exhausted
Edmond, OK
And then the set for the HID's too?
So a total of 3 resistors per side?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
correct, with your setup you'll have 3 per side.
alphaprojects
