Adding tow hook to a laraime
Toddbigboytruck
Ontario
hello all has any one add tow hooks to there front bumper I have a 18 Laramie although I like the look of the front I think I want to add tow hooks so eather I buy them on line or I go to a wrecker and pull a set off and repaint them
I know I will have to remove the plastic bumper inserts and mount the hooks. And think else I am missing
Cableman
Longisland
I just did this to my 2016 laramie, found a set on letgo for 75 and ordered the plastic fillers off amazon for 35. They are out there if ya wanna save a few bucks or just order from link above.
Toddbigboytruck
Toddbigboytruck
Ontario
Do you have a pic.
Toddbigboytruck
Toddbigboytruck
Ontario
Thank you. Will look into it.
2018 Hemi
Homie
I contacted Ram corporate office and complained about no hooks on a 2500 Tradesman with snow plow package and they contacted me back and to email them a price from my local dealer and they would pay for them plus installation and they did.. couldn’t believe it
Said to email
Toddbigboytruck
Toddbigboytruck
Ontario
Ill have to take a pic for ya, it looks like any other ram with factory tow hooks! They are factory
Thank you . Watch a YouTube video and it looked hard. He was going to cut holes in the existing inserts I have large hands and well it looked hard to remove the plastic inserts.
Cableman
Longisland
Oh no real easy if you get the factory hooks and plastic inserts designed to have tow hooks, took me about ½hr id say
fsClovis
Clovis, CA
Can you install these on an Express, the bumper doesn't look like it has inserts?
OC455
Central NY
There was a thread on here about how someone did it. But they had to cut holes in the OEM insert to run the tow hooks through.
OC455
Central NY
Buy the kit with the OEM bezels for the tow hooks. A lot easier than trying to cut the holes in the existing inserts. I did it with my Bighorn.
-remove the four 10mm bolts holding the insert in, slide it out from the side.
-slide in the tow hook bezels and reinstall the 10mm bolts.
-remove the nuts for the upper mounts and then slide the tow hooks through the bezel and then onto the bolts, install nuts and torque to specified ft.lbs.
-install the long bolt at the bottom through the rubber grommet and torque to spec.
-Done.
firefox9
