Adjust Default Volume settings
bigbob48
CA
ED
Hey all,
I have a 2018 1500 with 8.4 uConnect non-Alpine that I upgraded the dash 3.5's to decent Hertz units. There are no amps, just a straight swap of the dash speakers.
Now, I suppose it's because the new speakers have a higher sensitivity, the navigation, call etc volume is waaay too loud. I think it defaults to about 15.
Is there a way to adjust the default volume setting to, say 3?
I understand perfectly well how to adjust the volume in-call or during navigation, but it resets at some point back it's now absurd volume
Any solutions?
Thanks
Bob
SitKneelBend
St. Louis
3.6 Pentastar
Hey all,
Any solutions?
Thanks
Bob
If it resets every trip that's a bug. At present the only thing that may fix it is the firmware flash to 22.6. Do you know which firmware you currently have?
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
Hey all,
Any solutions?
Thanks
Bob
Did the startup volume change ONLY after you swapped the dash speakers?
Are the dash speakers real loud/bright compared to the stocks??
Did you put the resistors in line with the speaker install?? The ohm difference between stock vs aftermarket require a resistor or the dash takes over the sound.
Lots of threads here about this issue
I swapped all door speakwes but not the dash and dont have that issue
B
bigbob48
CA
ED
The volume SETTING is the same everytime I start the truck (15, which was always on the louder side for my preference) but since upgrading the speakers the commands are much louder at that volume setting. I'm hoping there's a way to change that DEFAULT setting to something lower so that when I receive a call, I'm not scrambling to crank down the volume
SitKneelBend
St. Louis
3.6 Pentastar
It's a bug. Do you know what firmware you are on?
mcv1
Utah/Colorado/Wyoming
6.7 HO Cummins
My 2020 3500 Uconnect3 (5" display) has a similar problem that is potentially related. I've heard others complain about my identical symptoms. It is the factory unit with no modifications. Regardless of what source I was using (typically a Droid phone via bluetooth or USB cable), the radio will default to volume 15 on SiriusXM on startup. Plus the screen is always initially disabled with that stupid "Accept" screen. So I'm stuck with 4 or 5 seconds of loud-blaring radio each time I start the truck before the volume knob is responsive. Interestingly, if I restart the radio within a few minutes after shut down, it defaults back to the same source and volume. But if the truck is off overnight, it will reliably go back to Sirius at volume 15. It remembers which Sirius station I was last on, but does not default back to the previous volume or source. BigBob, I don't know how to determine which firmware I have on the radio. I did just have my PCM flashed to the most recent update 524010032AG-AK but that did not resolve this problem. Is there another Uconnect firmware version I can locate?
The local dealer said they could try to update the radio software but that those flash uploads have been taking 5 to 36 hours and that I'd need to make an appointment for an extended service time! (not sure I trust that) Any other advice?
RamCares
n/a
n/a
Sorry to hear about that! If you decide to get this addressed by your dealer and would like additional support to make sure you're properly taken care of, please send us a private message so we can investigate your situation further.
We hope you get this figured out quickly!
Courtney
Ram Cares
Wirekat
East Kent
Cummins
This is exact problem I'm having. I would be listening through BT to my Android and shut the truck off and restart, the source is radio and loud. And I can't turn it down for five seconds.
mcv1
6.7 HO Cummins
Wirekat, I have been to three RAM dealers since I've had the truck. None have been able to fix the stupid problem. If you have any luck, let me know what to try!
