Aftermarket items have problems with factory air suspension
Jetact
Happy Valley, OR
6.7 HO
I have not got my truck yet but hopefully next week. I ordered a 3500 Limited with the rear air suspension. I have been looking at after market items and have come across a few that says that they will not work with the rear air suspension. Front leveling kits and air compressor/horn kits say they wont work, why?. I have not even seen the truck or undercarriage or driven it as I knew what I wanted so I just ordered it.
MADDOG
Living in a Firepit
6.4L HEMI
I had no problem with the rear auto air suspenson when I installed a front level on my 2014 2500.
A lift kit on the rear might be a problem. Never tried it.
If you wire in a compressor and tank for the air horns separate from the OEM rear air system I don't see why that would be a problem either.
Jetact
Jetact
Happy Valley, OR
6.7 HO
I was only looking for a level kit, this level kits says it wont work but I have no clue why. https://carlisuspension.com/product...m/dodge-2-5-leveling-system-2019-3500-diesel/
A lift kit on the rear might be a problem. Never tried it. I am done with lift kits.
This compressor and the kits they sell all say this also. https://kleinn.com/product/onboard-air-system-for-2014-2018-ramhd-2500-3500/
I will just wait and see the truck and build an air system myself like I did on my current truck and jeep. I wish I knew why These companies say that things wont work with rear air suspension in the new trucks.
MADDOG
Living in a Firepit
6.4L HEMI
It may be that some folks have tried to connect some of these systems to the onboard air for the rear air.
Now, most owners would know better but there are those who don't...
Jetact
Jetact
Happy Valley, OR
6.7 HO
That maybe it, so its a PSA to help those that don't do their research instead of a fitment issue possibly.
Honestly I didn't know that the rear air was a closed system until I read it here. I would have figured it out eventually after crawling underneath.
Our trucks are in and we are going to pick them up the first of the week, can't wait.
zrojas
US
Cummins 6.7
I replaced my front coils with 1.75" Thuren's. I had no issue. Then I added a 1" rear Ready Lift block for the rear, still no issue.
The level sensor for the rear air suspension is measuring the angle from the top of the leaf pack to the frame. Adding a block under the leaf pack does not make any difference as far as changing the relationship of that angle. They do have 1" and great spacers for the airbags, but it is not really needed for a 1" block. If I were to go to a 2" or greater left block or replacement leaf pack, I would add a space to the airbag as well.
Sent from my SM-G975U using Tapatalk
Jetact
Jetact
Happy Valley, OR
6.7 HO
zrojas, so you werent going for a level but a small lift. Did the 1.75" spring get you pretty close to level? I am looking at a 2.5" dual rate Icon spring with a 2.5" reservoir Icon shock to level the front.
zrojas
US
Cummins 6.7
The 1.75 Thuren coils on my 3500 with factory air rear suspension it the truck pretty much level. I thought it looked slightly higher in the front so I got the 1" block for the back. If I had got the 2.5" springs from Thuren I would have got a 2" block for the back. I think if you have leaf spring only in the rear, you'll be fine with 2.5 coils.
I don't mind the rake, but I wanted the whole truck a little higher closer to the height of my 4th gen.
Jetact
Jetact
Happy Valley, OR
6.7 HO
zrojas,
Thanks for the reply, I do have a leaf spring in the rear but also have the automatic air level back there. I am just hoping to be level so we will see.
zrojas
US
Cummins 6.7
zrojas,
All 3500s with factory rear air have leaf springs.
