Aftermarket steering wheel
ttthiel
Mid Michigan
So after doing some searching around on here I can not see to find any information about installing an aftermarket steering wheel on my ram. Anyone have an information at all?
RAMTRPR
"Enjoy The Little Things"
Brentwood, CA
I honestly have never seen one on a Ram. Only people that upgrade from low version to better but still OEM.
89grand
Phoenix, AZ
2019 RCSB
I went from the low rent Express one to a leather wrapped OEM, but I do believe there are some options out there, if OEM is not your thang.
ttthiel
ttthiel
Mid Michigan
Definitely want to get away from oem and all I have ever seen is people upgrade within the oem world. I can not find any information anywhere.
RAMTRPR
Brentwood, CA
Double post. There a are a few out there. I like the Ferrari type look too.
Purplert
Carbonfiberelement on Instagram will rebuild and customize a stock wheel for you... it’s not cheap though..
Unless it’s a full blown race truck or something just about anything other then oem will look out of place. You can however modify the stock wheel to your liking but going overboard on it will make it look out of place. Just my $.2
Marcus Bancroft
SC
I was thinking to change my Urethane wheel in my '10 for an OEM leather wrapped one, anyone done this before ? my only concern is transferring the airbag and all the controls over from the old wheel to the new, but presume its possible or they would not sell them.
Jho93
Savannah, georgia
2019 classic
I did it quite a few times when I worked at dodge. so getting the airbag lock tabs up and removing the bag can be irritating but there should be removal videos. once you get the bag out disconnect it (make sure the battery is disconnected for a few minutes before you even start the swap) and set it aside. unplug the remaining connectors from the wheel and use an impact to take the bolt out of the center of the wheel should be 13mm or 16mm then thread the bolt back in a few threads (so the wheel doesnt fly off and hit you) and smack the back of the steering wheel towards you alternating the left hand and right hand sides. when it breaks free you can swap them out and plug everything in just make sure to re apply thread lock to the steering wheel retaining bolt.
Friednice
Raincity
5.7L hemispherical combustion chamber
I upgraded my oem leather wrapped stock steering wheel to the Laramie Longhorn fancy leather and wood one, black wood too, looks awesome. Also noticed that the heat from the heated steering wheel is 5x hotter with the new fancy wheel.
Can confirm its a straight swap over
Dpressed1
Houston
Were/how much was the laramie steering wheel if you dont mind me asking? Ive been wanting to get one for my truck but theyre pricey
WhiteExpress
Midland, TX
Friednice
Raincity
1500ish Canadian if I remember correctly, I had a friend of a friend help me out and got a dealio. My oem all leather factory installed one was pealing/pitting at the top a year or 2 after I bought it and asked Chrysler if it was warranty. Sent in pics and they said NO SOUP FOR YOU!
Cheers
southalum
