steering wheel
  1. B
    Infamous steering wheel control issue has me stumped
    Truck 2015 Ram 1500 tradesman. Motor swap performed before I bought it donor motor was a 2017. Ivr had the truck 2.5 years and steering wheel controls have never worked. Guy I bought it from said they worked before the swap, but I dont know if I trust him. Cruise control and gear selection...
  2. Infotainment.com
    OEM Leather Steering Wheel w/ Audio Controls (2019–2022 Ram HD)
    If you’re driving a 2019–2022 Ram 2500/3500 Heavy Duty in Tradesman or Big Horn trim, you’ve probably noticed one thing missing compared to older generations: rear-mounted audio controls on the steering wheel. Ram reserved them for higher trims—but the good news is, you can add them back with a...
  3. P
    Replacing my steering wheel for my 2021 Ram 1500 Classic SLT
    Hello everyone! I am currently in the process of upgrading the interior/electronics for my Ram. I am upgrading the radio/speakers/speedometer cluster/Steering wheel. I am hitting a roadblock for my steering wheel upgrade as I purchased 5YK252X7AE 2019 Ram 1500 steering wheel for my 2021 Classic...
  4. T
    2023 ram 1500 limited steering column noise
    Hi all, I just recently purchase a 2023 Ram 1500 limited with 4k miles. It seems to drive amazing BUT when I make a hard left turn, the steering wheel/column makes a subtle noise when the wheel turns itself back to being straight. It sounds almost like an electrical buzzing or gears. Could it be...
  5. G
    Matching steering wheel covers
    Hey all!!! I have a 2019 1500 Laramie. My interior is beige and what I think is called mountain brown. My steering wheel finish is wearing badly and for the life of me, I can’t find a steering wheel cover that matches. I received 3 samples from wheelskins and no luck. The pic shows my steering...
  6. UnkoBro
    Adding Radio Controls to a stock steering wheel?
    2014 Ram 1500 Express; it came with a 5.0 Uconnect Radio without steering wheel radio controls. I added an 8.4 UAQ Nav/AA/CarPlay radio (thanks MP Grimm2) and considering adding THE CONTROLS to my existing wheel. I've purchased a new rear wheel cover with switch control openings (to swap) and...
  7. 1
    Steering Wheel Needed
    I’m interested in buying a factory steering wheel for a 1983 Dodge W150. Does anyone have one for sale that will fit the steering spline? Please see the attached image below. Thanks!
  8. 1
    Steering Wheel Swap
    I bought a 1983 Dodge w150 with an aftermarket steering wheel that I don’t like and want to replace. I bought two different OEM steering wheels on eBay, but the spline count appears to be different than whats on my steering column. Online research shows there are two different styles of steering...
  9. Jim 11
    Steering wheel and EVIC Cluster upgrade - HELP!
    I’ve read and re read the thread covering the proper wiring procedure with the pictures. I still can’t get any of my steering wheel buttons or horn to work. https://get.google.com/albumarchive/115651121177758204880/album/AF1QipNSLaFAq4zKa247XLaGUNYyujI3Lfg0C3OcBoIh?feat=directlink 2011 Ram 1500...
  10. regcabsplz
    98 - 02 steering wheel in a 94 to 97?
    Hi I have a dumb question, I recently purchased a 94' Ram 1500 and so far it's been a great truck with some pretty decent interior, the steering wheel however has always looked kinda ugly and is a bit chewed up. I could replace it with a better condition wheel from that era but I've always...
  11. D
    2019/2020 steering wheel on 2017?
    Hey All, Has anyone switched their steering wheel with a 2019+? Not having a hand hold at the bottom of the wheel is driving me crazy!
  12. XXSNOTRODXX
    Interior paint match mod
    For anyone out there with the darker gray interior accents like I have on my 16. I found an almost identical paint match that looks great and is durable . Rustoleum flat soft iron is almost spot on in both color and sheen. I color Matched my steering wheel bezel when I did the leather steering...
  13. XXSNOTRODXX
    16 steering wheel
    Selling steering wheel out of 16 ram with 33k miles on it. $50 plus shipping. PayPal . Thanks
  14. ttthiel
    Aftermarket steering wheel
    So after doing some searching around on here I can not see to find any information about installing an aftermarket steering wheel on my ram. Anyone have an information at all?
  15. M
    SOLD Leather Steering Wheel with Audio Controls
    I have a non-heated, black leather steering wheel with audio controls. It is in very good condition as it came out of my personal truck. I kept it well cleaned and conditioned the whole time I used it. leather wheel by Moparman16 posted Oct 1, 2019 at 11:15 AM $140 USD shipped PayPal F&F...
  16. M
    Steering Wheel Switches
    I have both the left (SOLD) and right steering wheel switches for sale. Both are in excellent shape. Left Side F3C4A96E-794E-4F32-BA8D-A9B24D9F4D6D by Moparman16 posted Sep 24, 2019 at 12:01 PM0542D02F-79EB-445F-847B-2A8C82519265 by Moparman16 posted Sep 24, 2019 at 12:01 PM SOLD Right...
  17. W
    Looking for advice on clock spring.
    I have a 2011 RAM 2500 with a 5.7 Hemi. My problems started with steering gear box, pitman seals blowing out. So I changed gear box. In the process of installing the new box, I somehow must have moved the steering wheel cause now the clock spring is broken, no horn no controls working on...
  18. C
    Steering wheel audio controls
    Trying to pinch some pennies so got into a Tradesman 2013 Ram 1500. I'm going to be replacing the factory radio with an aftermarket radio. Is there any way to install steering wheel audio controls with an aftermarket radio? So far, my research has told me no. Thoughts?
  19. M
    Upgrading/replacing steering wheel
    I own an ‘09 Laramie 1500 w the heated steering wheel. It’s getting pretty beat up w age and I was wondering if it’s possible to replace the original steering wheel with a newer and thicker 4th gen steering wheel?
  20. K
    Heater problem wirh steering wheel
    Hi guys, I have a ‘16 ram sport and I would lime to know if you ever heard that when I turn my steering wheel left I feel like the heater is getting more hot and when I turn right it’s getting colder. Thanks
Carbary
