Air Conditioner not working
Regularjay
I recently bought a 2013 Express 4WD Hemi crew cab. I bought it from a private party and have no warranty coverage and a visit to the dealer is not in the budget. We've had a couple warm days here lately and the A/C does not work, the fan blows fine but compressor does not engage. I have verified that the compressor is not getting voltage. To troubleshoot further I would love to know what relay in the underhood fuse box is for the A/C clutch but they are not labeled and I've been unable to find any info on-line as to what relay does what. Does anyone have any information about which relay controls the A/C clutch?
Thank you.
R
Regularjay
Thank you, I have a 2013 - The owners manual does not have any information for relays, only fuses.
R
Regularjay
I appreciate you are attempting to help but that is only fuse information, I am trying to figure out what relay (grey plastic boxes about an inch square) controls the A/C clutch. The fuse protects the circuit from excessive current draw. The relay is an electronic switch where a low current source (like a computer output) is used to control a high current (A/C Clutch) load. My fuse is good, the next troubleshooting step is to verify the relay operation and none of them are identified.
Racer_X
Have you put gauges on it and made sure the system has a full charge? If it leaked down the safety circuit won't engage the clutch.
I had a similar failure on my 2009. Ended up being the clutch coil failed.
Sent from my hammer and chisel using Tapatalk
sigsauerP938
