Air ride suspension lowering
RAM20142500
Sidney, MT
My Truck is a 2014 2500 with air ride that keeps lowering to the bump stops
I am having a problem with my air ride lowering, i replaced my level sensors filled my tank with nitrogen and still cant keep them up, ill be driving for 10 minutes and then get a service air suspension soon then the driver side air bag will start loosing air then the passenger, the compressor will not kick on and start filling it back up once the service air ride comes up. It will fill back up once i stop and turn off then turn it back on. Does anyone have any idea what i can do to fix this?
jimmylangley
Kentucky
Unfortunately, I have extensive experience with air ride problems. One thing to check is the steering angle sensor. If it’s off by more than 10degrees the system will enter a safe mode after a while which would explain the lowering and service notice. Get an alignment and it should work. You can reset the system in the ABS module or steering stack using Alfa. Otherwise it may be leaks in the lines or solenoid.
