Air Suspension Delete
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
My 2500 only has the rear air suspension from the factory. It was leaking down on its own after I had a tranny replacement done at the dealer. Took them 5 weeks and over $5k in parts to fix it. Thankfully I had a extended warranty. Otherwise I was going to do the delete too!
Jacob Maguire
Pine Beach NJ
Hemi5.7
I ended up going the more “affordable” route. Rough Country struts (2” Lift), Rough Country M1 Shocks, Eibach Springs (+1”), and new isolators. For me personally, the way I use my truck, Fox was overkill and way more $$ than I wanted to spend. Truck rides SO much better. The air suspension on mine was rough, felt every crack/bump/dip. It was time for it to come out. Used AlfaOBD to delete it from the BCM and it’s like it was never there. Best mod I’ve done to this truck by far.
I'm having trouble finding information regarding the configuration changes needed to be completed in AlfaOBD. I have the app and bluetooth ODB2 connection. Just need the step in Alfa. Would you be able to share?
Jacob Maguire
Pine Beach NJ
Hemi5.7
UPDATE:
I came across the following in another thread. Connected AlfaOBD, located and connected to suspension control mod. Scrolled through but not seeing these parameters:
You can completely disable everything with AlfaOBD, as if it was never installed. Make these settings changes:
P/T Chassis Net ASCM Air Suspension Control Module- DISABLE
VehConfig 7 ASCM contains suspension- NO
CustSetMenu 1 Tire Jack Mode CSM Present- NO
CustSetMenu 1 Air Suspension Warning CSM Present- NO
CustSetMenu 2 Transport Mode CSM Present- NO
CustSetMenu 2 Wheel Alignment CSM Present- NO
(from: https://www.ramforum.com/threads/help-four-corner-air-suspension-problems.204794/)
Open to suggestions; thanks in advance
