Norman Roach
FYI, Air leaks all fittings. The problem is O rings on all the fittings are SAE, they need to be replaced with Metric O rings. The problem is the O ring on the outside of the fittings. There are 17 of them. The O ring inside the fitting is OK. Each fitting has two small O rings where the tube goes into the fitting, they should be OK. Use a dental pick to pull out the external O ring on the fitting, use a metric one which is a little thicker, use white grease on the fitting, coat the new O ring and push it onto the fitting. DO NOT USE SEALANT. To install push hard with your hand to keep the fitting straight while tightening with 12 mm metric wrench, check it to see if it started be careful NOT to cross thread it, tighten to bottom it down. You will never see bubbles on these fittings with soap and water, the leak is too small. Try to tighten each fitting before you start, the fitting should be bottomed out, Mine were not tight. That will fix your problem.
