Alfaobd won't install?
miles01
Alberta
I am on the Alfa web site and am trying to install the app on my pc but it won't install??
anybody know why
SeppW
Northern VA
Hemi 6.4L
Asking the obvious, are you downloading the PC version? Did you pay for it? Is your PC virus program blocking it?
noodles
woodbridge, va
2018, security (spy eye) bypass may be needed. Since you are the beginning of the "You have no idea what you are doing. Therefore, big sister will hold your hand..." era.
M
miles01
Alberta
I got installed and activated.
But now I can't change the tire pressure setting or keep fog lights on when high beam is used. Staring at the low tire pressure light is getting very old on the 2500. (I have my truck pin from the dealer)
These two items are the main reason I got.
I installed the security bypass, and am using OBD MX.
My pc connects to the OBDMX and the Alfa program say connected. I can only read the factory settings and codes.
WTF, this is not the reason for spending over $240 CND on the security bypass, OBDMX and the Alfa program.
M
miles01
Alberta
Ok
I emailed ALFA and they responded very fast today (within mins)
emailed me screenshots and explained how to access the changes.
Tire pressure warning for the rear tires is now out unless less then 50psi.
Fog lights stay on when switch to high beams.
Perfect
Kroni
New York
Miles01
I am looking to do the same thing. Can you please post up screenshots?
Thanks
