Looking for a towing cam
thxdood
MN
I just had my transmission built for towing and am wondering if there is anything else I SHOULD do once I install a cam or if I can simply install the cam and be good to go? Also looking for recommendations on a good towing cam....Im going with The Truck Norris as of now in remembrance of a Legend Thank you in advance!!
You're asking for cam reconmendations,"but" you're going with the Truck Norris cam in rememberance of a legend. I'm gonna say you've probably confused alot of us with this post.Why do you want a reconmendation,when you've already made up your mind,seems counter productive to me :rolleyes:
T
thxdood
MN
You must only read certain words and then look for an arguement based on what your simple mind comprehended (must be becuase your a 'wild one' lmao) If you read all the words that I typed I said AS OF NOW that is what I would be going with....since youve done nothing to answer my simple inquiry, Im going to assume you only speak for yourself and not "alot of you" in this group.....thx for nothing!
Boy you're the King of back pedaling aren't you :Big Laugh:
Good thing i quoted your post so you couldn't change it bud,as here's exactly what you said;)
Maybe you should learn to read your own posts:waytogo:
"Im going with The Truck Norris as of now in remembrance of a Legend Thank you in advance!!"
Not sure how you read that,but i read it as "You're going with the Truck Norris cam as of now"
How you expect the rest of us to read it any differant,is only in your mind;)
Are you having a bad day,as it sounds like you're off your medication :Big Laugh:
I only stated the obvious,you apparently didn't like it,and went off your rocker:Big Laugh:
Nodody but you,is looking for an arguement,i got better things to do tonight then argue with some guy who can't even read his own posts :cheers:
Have a good evening but i'm out and sure as hell not going to reconmend squat to you,as you might get all up in your druthers if i gave you another cam selection to consider;)
star_deceiver
Airdrie, Alberta
3.6 Pentastar
Yes. Sell it and buy a 2012 to 2018 1ton. The Cummins paired with any of the 3 transmission offerings will change your world and you’ll wonder why you bothered trying to tow with a small truck.
DILLIGAF
Canadian Forces
Canada
Id be more worried about who ever lied to you about a POS 6 speed thats built for towing, because thats not a thing :dogpile:
Marshall
Sk, Canada
2014 sport
Any time I was worried about towing, first thing I looked at was the rear end gearing ratio, and went different on one truck I had . just a 2wd so simple.
I don't know how trans. would make much difference other then shift points and you can do that with the wheel controls.
2015 I presume would be a 8 sp?
Speaking of cams, I seen a new trailer with rear camera , neat idea as My x ray vision never worked when I use to pull trailers.
Mind you that trailer cost about the same as a house these days.
Austinv
