Cthulhu
- Oct 13, 2011
- 833
- 99
- Location
- Calgary, AB
- 2006
- Cummins 5.9
Hey guys/gals
I took my truck in to precision alignment this weekend in Calgary AB... the truck has been pulling to the left quite a bit... wondering what you all think of the quote they presented me with...
1. To replace the track bar (whole thing), the long drag link to adj sleeve, the short drag link to pitman, a new bracket for the steering damper (which Dodge said we would need as they changed it AGAIN!),
including all the (Dodge) parts, labour, alignment, materials and enviro fees = $1245.08 + tax = $1307.33 all incl
2. To replace the track bar “bushings" on the bar, (aftermarket bushings as Dodge does not sell them separately), the long drag link to adj sleeve, the short drag link to pitman, a new bracket for the steering damper
(which Dodge said we need), including all the parts (mostly Dodge), labour, alignment, materials and enviro fees = $1014.18 + tax = 1064.89 all in
We MAY be able to get aftermarket 2008 Dodge RAM 3500 parts that would work, but I didn’t look that up today....I will if you want it.
3. To replace the front differential pinion seal including the seal, labour, fluid, materials, enviro fees is $253.83 + tax =$266.52 all in
On the quote above, apparently my steering has been upgraded to 2008 standard... Thats why they are talking about '08 parts as 06 won't work on the newer steering.. correct?
Thoughts?
Thoughts?
