All O2 codes at once but truck runs fine
63a
04 4x4 4.7, 144k, truck runs great but CEL and trouble codes for all four O2 sensors (p0135, p0141, p0155, p0161). I need to get the truck inspected and the CEL is going to be a problem. Seems odd that all four sensors would go bad at same time so i suspect there may be another issue. O2 sensors were replaced apps 20k ago.
Anybody else have a similar problem?
Thanks
RotorHead04
MA
Just because your O2 sensors are giving off codes doesn't mean they are bad. That is a big misconception. They are reading a fault in your air to fuel ratio. You are either too lean or too rich.
RotorHead04
MA
Have you done any recent maintenance or mods?
racer7
Needs a pcm, the codes are for the heater circuits, if you test it you'll find your missing ground for the o2 heaters
