AlphaOBD setting for parking lights?
vlamgat
I would like to be able to keep my parking lights on for longer than the standard setting of 10 or so minutes. Does anyone know a settting that permits this in the BCM. Vehicle is a 2020 6.7 5500.
Randy Grant
Army
KITTITAS, WA 98934
Try typing "ALFA OBD" in the search window. There are about 700+ pages of info that you can search for yourself.
V
vlamgat
I did but nothing comes up relative to the power delay switch process or the it's lighting actuation. So this was a last resort pitch JIC. But I think the power timer is hard wired in a relay somewhere.
Randy Grant
Army
KITTITAS, WA 98934
More than likely the setting is a fixed number and cannot be changed. Most ECM/BCM settings are either on or off, but get alfa and required peripherals and take a look in the settings.
V
vlamgat
I have it but cannot find a setting and had hoped that it was hidden somewhere obtuse. I checked the remote start settings which might relate but nothing obvious there. And yes I have the bypass cable.
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
I can find nothing for just parking lights. From my manual, but it's a '16
Dean2
Near Edmonton
Try leaving your park lamps on using your headlight switch. See if the vehicle shuts them off on its own, like it does interior lights left on, and how long that takes.
Randy Grant
Army
KITTITAS, WA 98934
It does or my battery would be dead, but I never stuck around long enough to see what the time was.
