Alpine system question
Curt2016Ram
South Carolina
So I know I'm getting old, but my Alpine system does not seem to be as loud as when I got the truck in 2017. Level 17 was kickin' pretty good when I had my phone connected via Bluetooth. Now I have to take it up to 23 to get the same results. The rears don't seem to be very loud at all. Is there maybe a setting that was reset? The bass, mid, and treble have not changed.
MADDOG
Out Exploring Arizona
The only things I can think of is to check front to rear and side to side balance, pure stereo vs. surround sound setting and go around to each speaker and listen to it to determine if one or more have failed.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
I noticed a huge sound reduction listening to FM HD radio when my SiriusXM ran out. It was like night and day difference at the same volume. Enough that I got another subscription to Sirius within 1 week.
Could be balance, or fade, eQ settings could have reset if u changed a battery or had a pcm flash or an auto update done I’d the truck is 18 or newer. Or worse case the stock amp blew the rear channels or the speakers went. Easy would be to replace rears with decent 2-3ohm aftermarkets and see if there is a difference.
C
Curt2016Ram
South Carolina
Balance is in the middle and EQ are the same as well as the speed setting (volume change as you speed up or slow down) at 3.
TomT
SoCal/OC
There is
Is the surround sound on or off? What about the fader, is it centered? You can use the balance and fader controls to isolate each corner.
You say that you use Bluetooth, any chance the level on your phone has dropped due to an update or setting change? Have you tried comparing Bluetooth and USB to see if there is any difference? What model of phone do you have? Can you test it with another phone to see what happens?
C
Curt2016Ram
South Carolina
Surround is on and everything is centered. The sound is the same with Bluetooth and USB. I have an S7, but can pair my daughter's phone and see if there is a difference.
Pudge
Alberta, Canada
2021 Power Wagon 75th
My iPhone through USB is much louder than my iPhone through Bluetooth. I’ve never been happy with the volume though Bluetooth.
Witch
Hemi 5.7 liter
Maybe up the game with some aftermarket audio equipment ?
TomT
SoCal/OC
Just for fun, turn off Surround and Speed Sensitive and see if that makes any difference. Were you able to check each corner individually and see if just one of them is lower than the rest?
