Alternator eater
Cold Tooth
AUSTIN, TX
I searched the threads and found one instance of a similar issue on a Cummins. I have swapped out my alternator and within three days, it is giving out. It is a reman, but seems unlikely that I got a bad break. It’s the exact same issue as the original. I hav measured resistance on grounds, battery and alternator cable. They are measuring within limits. I am stumped. Anyone have this issue or know of a fix? Battery is also brand new. For good measure, I am going to run new ground cables and a new alternator cable. I’d love to hear your ideas. Belt tension is good. Pulleys turn smoothly. No wobble on any pulleys. Oh yeah, brand new SERP belt. Thanks in advance.
Tl806
Dallas
Same thing happened to me. 3 alternators in 5 days. Finally went to the dealer. It was a bad PCM.
C
Cold Tooth
AUSTIN, TX
This is where I have landed. Truck is at the shop now. I am fairly positive I’ll be following in your steps. Getting my checkbook ready...
ILLXJ
Illinois
Had the same issue on a Subie. Got an alternator from the dealer. It's been fine since then.
JIM.
joshhhh
