Alternator not charging!?
Explit Player
Bristol, TN
On my 05' Dodge Ram 1500 5.7
Man.... my alternator is not charging my battery. I was sitting in a parking lot before school, then the check guages light came on and the battery was showing very low voltage. My autoshop teacher and I thought It was the alternator. I have replaced the alternator today and I had no luck. So I replaced the battery, so now I have a brand new battery and alternator. STILL NOT CHARGING. The battery tested as good. The alternator tested as good on 3 different machines.
My question is what is the problem. Appearently the voltage regulator isnt kicking on or im not getting connection or something.
Is there a fuse that connects anywhere on the alternator that would be blown?? I checked the fuse box and couldnt find a thing.
PLEASE HELP, the truck is my daily driver and im screwed right now....
dmacell1
levittown PA
hemi 5.7 supercharged at 10psi
Are the terminals loose or dirty?
Did you check for possible corrosion or maybe a bad ground?
joshhhh
