amp for 8.4 six speaker?
18ram18
st louis
I have a 2018 ram 1500 with the non alpine six speaker stereo system. I Just purchased replacement speakers: kicker 6X9 3 way for the rear, kicker 6.5 2 way for the front doors, and kicker 3.5 2 way for the dash.
If the factory stereo needs more power can i install an amp for this set up? Im not looking to install a sub...just maybe something to push the new speakers.
Elevated 2013
Huntley, IL
You can install an amp on anything. It’s a matter of what connections you’re given out of the stereo to the speakers. With the Alpine system (I know you don’t have that) there’s a DSP in line right after the stereo that’s in the drivers front kick panel.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Yes sir, and to make tuning easier, maybe consider a 6 channel amp to tune each speaker.
18ram18
st louis
I wasnt sure if the dash speakers would need their own channel or if they were fed from the front doors
18ram18
st louis
Is there a wiring harness that would go from factory radio to the amp?
Graygoose
Oklahoma
Convert, for now.
small
The doors and dash are connected, so if you want each channel tuning, you can do a 6 channel, or 4 channel add resistors on dash to padden them down a little.
This may be the easiest option.
Graygoose
Oklahoma
Convert, for now.
small
Yes depends on the amp, you can go speaker level, or get an LOC.
canadiankodiak700
Northern Ontario, Canada
3.7L Pentastar
may i ask why you went with 6.5 for the font doors instead of 6x9?
have yu installed any of the speakers yet? if not, can they be returned? if so, i have a recommendation for your system.....
Six8888
Houston TX
What’s the recommendation? He can also add a dsp before the amp to restore sound quality stripped by the factory head unit.
Steve58
