ramhunter9
- Jun 25, 2010
- 24,464
- 975
- 2012
- P-Star Jeep Wrangler
DBTC is proud to announce we are now offering Bestop Power Running Boards AND AMP Research Power Boards !
PowerBoard by Bestop
The PowerBoard step descends up to 6 inches, which provides a comfortable stepping height.
All PowerBoards include bright LED lights, automatically lighting the PowerBoard when it's needed.
Full length board works with both front and rear door, driver and passenger.
3 year/36,000 mile limited warranty
Step descends up to 6 inches to a comfortable stepping height
6.25 inch extra wide board made of extruded aluminum with ultra-durable powder coat
Non-slip textured surface
600 lb. load capacity per side
Integrated LED Light Kit included
Pressure sensitive pinch-proof technology assures safety
Sturdy, cast aluminum alloy arms
Climate and salt spray tested, corrosion resistant, dependable operation in any weather
Complete kit includes two steps, wiring harness with controller, weatherproof motors, LED light kit and hardware
A real cool video
[yt]0Hc0XXLOXM0[/yt]
The AMP PowerStep
AMP Research PowerStep
Integrated LED Light System - Standard
High-strength, die-cast aluminum-alloy linkage arms, anodized and Teflon® coated to resist corrosion
Precision, zero-maintenance stainless-steel pivot pins
Extruded aluminum steps with a textured powder-coat finish for maximum grip and durability
600 lb load capacity (each side)
Weatherproof, OEM-quality electric motors and wiring harness with sealed weather-tight connectors
5-Year/60,000 Mile Warranty
[yt]2q0XL2Lusj8[/yt]
A real cool video
The AMP PowerStep
