Another negative offset question
Mikegb
Dartmouth
will 305/55/20 tires rub with -24 offset. 20x9 rims
I have a 2.5” level kit
quietpeen
2021 TRX
Hellcat
I don’t think they make -24 mm offset 20x9 wheels do they?
cyberpine
No leveling kit.... 20x10 -24 wrapped in 33x12.50x20 with no rubbing what so ever. fe318d688ff8d679a0915df943849747.jpg
@konfused, I know this is an old post, but is your truck 2wd? no leveling or lift right? really absolutely no rubbing? What tires were these? did you suffer MPG loss? Damage to suspension from wider? got any more pics? Anybody else running wider like this?
Thanks in Advance!!
KahneFan
Buda
Perfect timing! I'm looking at some 20x10 -24, and I currently have BFG K02 275/60/R20, so it should come out similar.
McBroom
Denison Tx
Hemi 6.4L
My 35x12.5-20 on 20x10 -12 rub a little bit on my 2500 with stock suspension. I’m hoping that I get a level kit for Christmas [emoji1694][emoji1694]
Blue Streak Pearl off-road
Reactions: JB1
cyberpine
perhaps not emphasized in my question , but I think 2 wheel drive vs 4x4 seems to present issues with wider/bigger tires. All your trucks are likely 4x4...
And naturally (and needless to say but for clarity) a 20x10 is a very wide rim and so a more negative offset sticks out further and can help with clearing the suspension but then has problems with the fenders.
Anybody know if @konfused's truck is 4x4? should be a profile question, but is not I think.
cyberpine
bump... anybody? BTW anybody remove, trim or pull back their front wheel liners? Hearing this will rub the outside top of the tire right in the middle of the liner which on my truck is already very lose and thin.
BEAST19
Not sure if this helps but I’m running 20x10 -18 offset. Fender flares are bushwhacker pocket flares with 305-50r-20’s with no running issues . 4x4 with a front and rear ready lift sst leveling kit
cyberpine
saw a truck today 2wd, no lifts with 20x10 -18 and 33/12.5 slight rub on lock outside top corner of tire in middle top front of the front liner... not a great spot for cutting, but somewhat cosmetic rub seems a lot of play to pull the liner forward somehow.. I think -24 actually might make that rub worse. not looking to lift.
https://www.ramforum.com/threads/tires-rubbing-inner-fender-fix.48141/
cyberpine
This guy took his front liners off and was able to fit 20x10 -24mm offset with 37s! wow. I am presuming 37x12.5?
bfill_rebel
Nice looking truck you got there. Fender/tire/offset combo looks great
BEAST19
Sir thank u sir .... big change from a couple weeks after I bought it . Only thing I would change would be not getting 10ply tires . They were a ***** to balance and are overkill for what I dô robbing me of some mpgs
KahneFan
Buda
Where'd you get the hood? Like it?
BEAST19
Thats a smexy hood. Where did it come from, cost to match paint?
Sent from my SM-N950U using Tapatalk
Amerihood is the company ... fiberglass . Hood was about $500 then andother 500$ to paint and install
konfuzed
Texarkana, Texas
5.7 liter Hemi
Thanks in Advance!!
14' 1500 lonestar 4x4. Dfg crusher 20x10 on 33x12.5x20. I have it leveled now. But no there wasn't any rubbing. The tires are radar renegades, they were really cheap however I'm at about 50k miles on them. So I am impressed with them. They are loud as **** and yes major drop in mileage. I'd say 3 to 4 mpg's. I have done some other upgrades since i last posted.....
0d79caaa5f812dfae412a2a8a9bc5013.jpgf7ac588a9469e6f131e4b12660421f0a.jpg20e07ef5988959198962bd8dca9957cc.gif5228ff1872d7a02eb4c5ceac22459b44.jpg
No members online now.
geneseedennis
