Anyone HAPPY with Borg Warner 44-44 / Auto 4WD
7777xm
Covington, GA
I'm still waiting for that video with the binding.
Sent from my Nexus 6 using Tapatalk
I tried. It's hard to capture a video of driveline binding. I also have a delete so it's hard to hear too. When the right opportunity comes, I'll get it.
Sent from my SM-N920T using Tapatalk
clh1220
st Louis
I'm not going to go do a video. But in all my years of having 4wd. I can tell you it feels violent when it's binding and you will want to stop right away. In low side it feels strange when it's not locked in. But totally different when it is.
loveracing1988
Clarkston, MI
Well considering I have yet to see a truck with this transfer case bind color me skeptical. I know the 3 I've ridden in haven't had any sort of binding whatsoever.
Hemi395
Cape Cod MA
Should be a pretty easy video to capture. The steering wheel should start jerking if it is truly binding.
yillbs
Too bad another thread gone for a ****.......
This entire thread has mentioned nothing other than the bw44-44 transfer case. THat's not ****, that's informative. Can you not see the numerous people with different results ? It's a good conversation, go sit in the corner.
clh1220
st Louis
You did get that I was saying it doesn't bind because it's not engaged till a rear wheel spins.
iam_canadian22
northern ontario
After reading and posting on this tread I've learned that once you go past the Outdoorsman trim you automatically get the 44-44 TC. Except for leather and lumbar support on passenger side you can load up an Outdoorsman with just about every option available. Any thoughts?
Thats exactly what i did, traded the sport for an outdoorsman that has almost every feature the sport had. All good now.
VB712
Maxi_built
Va Beach
Got stuck yesterday in snow/ice. Put the truck in neutral, put it in 4lock, drove right out!
quietpeen
2021 TRX
Hellcat
4 lock as in 4 low or 4 hi?
Murphy Slaw
Murphy Slaw
Southern Illinois
2016 Bighorn 4X4 Crew
We've had a TON of rain and I used my new one Saturday coming out of the woods. Simply hit "auto" because the trail out of my cabin is pretty much just a trail.
Worked flawlessly, quiet, smooth, zero drama.
muddy12
Indiana
I've only had my truck for about a year, and only gone through one mild winter with it, but as far as the performance of the case; I have no complaints so far.
However, it seems to me that the front output, being that it sticks out so far without support, could be a potential week/failure point.
Ken226
Washington State
BW44-44 transfer case
I've been following this thread, and others like it since I bought my sport in Feb.
Out of curiosity and concern, I've done some testing and disassembly to try and figure out how this TC works. I have a mechanical engineering background, so the mechanicals are very simple. The electrical and computer controls took a little more effort.
The part of the system that seems to be questionable is a three part system, called, and patented by a BW engineer, the electromagnetic clutch with ball ramp actuator and torsion spring.
The ball ramp can simply be thought of as a type of big ratchet. This is why the system doesn't bind, the ball ramp acts as a ratcheting mechanism between the front and rear drive systems. When turning, and the front wheels are following a larger radius than the rear wheels, these ratcheting mechanism (ball ramp), allows the front wheels to rotate at a higher speed than the rear wheels. Simply put, if your in a turn and have good traction, then you're being pushed along by the rear wheels only. Should the rear wheels begin slipping such that their speed becomes = or > than the front wheels, the ball ramp will start driving the front wheels too.
Next I'll discuss the electromagnetic actuator, torsion spring and the clutch pack. I'll refer to the front drive system, it's associated clutch plates, shafts, wheels, etc, as the "driven" system. Also, I'll refer to rear wheels, clutch plates, ball ramp, etc as the "drive", system.
In a nutshell, the ball ramp is disabled, and no torque throughput allowed, unless the electromagnetic actuator is energized, thus enabling the ball ramp. When the electromagnetic actuator is energized, the ratcheting mechanism between the driven system and the drive system is engaged. So, regardless of the knob setting in the cab, the entire ball ramp clutch system can only exist in 2 possible states energized, and not energized.
The system doesn't use the typical pressure plates/springs found in common clutches, rather the ball ramp itself applies the compressive forces between the clutch's drive plates and driven plates. As the ball ramp, is a torsional ramp, like a screw, the more torque = more compressive forces on the clutch plates.
So, in a nutshell. When the electromagnetic actuator is off, the clutches are disengaged.
When the electromagnetic actuator is energized, the rear wheels will need to spin about 1/2 turn 180° ramp/ball arrangement, before the ball ramps apply sufficient axial force to the clutch plates to engage the front, driven system. If you let off the throttle, then the torque differential between the drive/driven systems dissapear and the torsion spring returns the ball ramp to it's unlocked position. If you then mash the throttle again, (assuming the electromagnetic actuator is still energized), the rear wheels and hence the drive portion of the ball ramp will rotate untill
it catches up the the driven portion of the ball ramp (within 180° of rotation (2 180°opposed balls/ramps). , like a ratchet, it will begin rotating the front, driven, system again.
Now, to the electricals:
Really simple, I isolated the circuit under the truck, that controls the electromagnetic actuator, and put my multimeters hall effect coil around it. Testing in mud and snow in the north Cascade mtns.
4 auto only shows current when the rear wheels slip. So, in 4 auto, when the rear wheels start slipping there is current flow to the electromagnetic actuator. As soon as the front wheels start spinning at the same speed as the rear, the current flow disappears. The front wheels continue to spin in the mud, even without the electromagnetic actuator powered. Obviously as long as there torque being applied to the ball ramp, they stay locked together. If I let off the gas then hit it again, same results. Rear wheels spin first, then the multimeter shows current flow and then front wheels spin. Front wheels reach the same speed as the rear the the multimeter shows the current turns off. All wheels continue to spin untill I let off the gas.
Now to 4 lock and 4 low:
The circuit to the electromagnetic actuator shows current flow. At idle, at all throttle settings, and with the steering wheel turned from lock to lock.
This means that in 4 lock or 4 low, the determinant factor will be torque applied to the 2 halves of the ball ramp. If there is sufficient torque to overcome the torsion spring, the front wheels will be driven. If there isn't, they won't.
The videos posted showing a vehicle at idle, in 4 low, with the rear wheels only turning are likely the result of the drive system not applying sufficient torque to the ball ramp, to overcome the torsion spring and engage the driven portion. It may be that so little torque is applied to the ball ramp under those conditions that it simply isn't engaging. If it took more than the smallest amount of throttle to get the front engaged, then likely there's a problem.
Possibly something out of adjustment or clearanced incorrectly.
So, in summary:
2wd:
no power to the ball ramp, only the rear wheels pushing.
4auto:
no power to the ball ramp unless, rear wheels spin faster than the front, computer momentarily energizes the ball ramp and the rear drive system engages the front, driven, system untill rear and front wheels speed match. Front system is driven untill front wheels rotate faster than the rear wheels, such as in a turn, thus allowing the balls to drop out of the ramps. And disengage the driven system.
4lock and 4 low:
Under all conditions the ball ramp is energized. Any time the rear wheels (drive system) rotate faster than the front wheels, the ball ramp will ratchet the front (driven system) along at the same speed. If the front begins tracking around a larger radius than the rear (all turns), the ratcheting nature of the system will allow it to do so freely, with no binding. (Theoretically, if you turn at a radius that advances the driven system 179° beyond the balls engaged position, the next time you encounter a slip situation the rear wheels will spin appx 1/2 turn before the front engages).
This little review shows only the facts. I have no opinion regarding the comparitive effectiveness of this system, as I'm not an off road enthusiast. I'm a nerd. This system could be the best thing since sliced bread or complete garbage and I wouldn't know either way. My truck is very pretty though��, in it, from a distance, I look kinda off-roadsey.
Hope this was helpful.
Murphy Slaw
Murphy Slaw
Southern Illinois
I'm not either. I want to get through the muck, and move along.
I don't go LOOKING for muck.
Excellent write up, I think most of us would be concerned mostly with the durability and longevity of the system being used in a NORMAL manner.
However NORMAL means different things to different people, and there are a lot of different climates involved in North America alone.
Reactions: SyN
muddy12
Indiana
I had my first somewhat disappointing experience with the 44-44 case this weekend. I was backing my trailer, loaded with 1ton of sand, into position in my yard. Had to back up an incline that was slightly off camber. Had the truck in 4lo, and still got enough wheel spin before the front engaged, that the back end would start to slide.
Hemi395
Cape Cod MA
Had the exact same thing happen
cbsmith
New Brunswick, Canada
2014 Ram 1500 Outdoorsman
I've been saying this ever since I tried one. It works great down down a road or anywhere at a decent speed. Low speed, off and on gas, will show these issues. And while they may not be the majority of driving done with these cases, it certainly is a pain and greatly reduces the ability of the truck in theses situations.
Last week I had a 3 ton mini excavator on a 2800lb trailer and had it to back it up my gravel driveway at the cottage. Was thankful I had lockable case during that as based upon backing my 4000lb boat up the same driveway was a hassle with the rental I had.
SportyJames
Corpus Christi
2015 RAM 1500 Sport
Since I live so far South, I only get to use in the rain. It's a very convenient feature.
WilliamS
Tampa FL
Just need someone smarter than me to either get into HP tuners and see if they can change the maps for the center differential based on mode, of if a switch can be added to flat out lock it.
Hemi395
Cape Cod MA
I emailed Sean at Hemifever and he does not have transfer case access. That would've been great if he could have tuned it to have the clutch stay engaged while in 4Lock and 4Low
Reactions: SyN
bbramer0820
