Anyone tow with a 2500 and 5.7?
SeventyGTX
I currently pull our small 24ft travel trailer with my 1500 5.7/8spd w/3.92's and it does fine. My only complaint is the mushy air suspension which gives a bit of an uneasy feeling at times. I have had 3 previous 2500's with Cummins 6.7's but was puliing a 5th wheel back then so I know how much better the ride is when towing with an HD truck.
Anyway, I am looking to upgrade to another 2500 and came across a very clean 2016 Longhorn with only 55k miles on it. BUT it has the 5.7 instead of the 6.4 along with 3.73 gears and 6spd instead of 8. So it's a little taller rear gear and less transmission gears. Does anyone have experience towing with the 5.7 and 6spd 2500? Thanks for any opinions
rzr6-4
nebraska
'09 2500
Sounds identical to my brothers and similar to mine, I just have the 545rfe (5 speed) instead of the 6 speed you are talking about.
Will handle that weight no problem, just don't expect to get good milage. You'll be at 3000+rpm going down the interstate pulling that wind sail. Pulling that all the time I would consider a diesel, for a daily driver that pulls once in a while it'll do fine.
SeventyGTX
SeventyGTX
Funny you mentioned the 5 speed. I had one in my 2009 1500, then got a 2012 1500 with a 6 speed and the difference was amazing from memory. That is really why I am concerned about the difference between my current 8 speed and the 2500 with 6 speed. Plus the slightly taller 3.73 gear and heavier truck weight.
I am still looking at diesels. But I don't put a lot of miles on my truck, around 2-3k per year and know it's not good for diesels to sit for long periods. Just got to fire it up and drive in on occassion. Plus as I'm finding out, diesels REALLY hold their value.
As far as RPM's, I'm not concerned about that. We had a 31ft Class C motorhome years ago with the Ford V10 and that thing screamed near 5500k pulling steep grades towing my Jeep Liberty. We said no more motorhomes after that unless the day ever comes we can afford a diesel pusher. Which is highly doubtful.
2003F350
6.7 CTD
My FIL had an '03, 5.7/auto with 3.73's. He pulled a Jayco Eagle fifth wheel with it, and it did NOT like it. It did it, yes, but it had to run 3k+ to get the job done. Suspension wise it was fine.
We put that same camper behind my '99 F250 PSD that I had at the time and it was a night and day difference. He ended up switching to a diesel, and we ended up buying the Hemi off him for my wife to drive.
outofthebox
canada
Just got 2016 ram tradesman crew short box and pulled first load. Its a 2500 with 5.7. I pulled 31' bumper hitch camper weighing 9500 lbs. on flat ground. at 55-60 mph. Rpm was 2000-2150 all temps were normal and it average 20 degrees lower on antifreeze, transmission and oil temp compared to my Eco diesel 1/2 ton. I didn't bother putting on weight distribution hitch and the truck barely squatted and pulled fine with-ought swaying.
Empty weigh pushing 20 mph head winds the truck holds overdrive until I climb steep hills. 1600 rpm at 60mph and jumps to 2500 on steep hills. First tank was 12.5 USA mpg with 30% pulling trailer. Empty I get 13-16 USA mpg depending on winds. This truck has headache rack including strobe lights and full toolboxes in back. Everybody on forum will tell you the 5.7 is a dog and get the 6.4 but the 5.7 does the job just fine as far as I'm concerned. I hope this answered some of your questions.
Dean2
Near Edmonton
I like the 6.4 better than the 5.7 for towing but I could live with either. However, if I was going to spend the money to move up to a 2500 from a 5.7 1500 8 speed, I would make sure it was the 8 speed transmission. The difference between the 6 and 8 is night and day and with tow haul on, even more noticeable. The ZF is just a hugely better transmission. For 3,000 miles a year pulling what little weight you are, a diesel would be nice, but sure not mandatory.
mtofell
^^This
I've never towed with the 8 but can attest to the fact that the 6spd sucks towing heavy. A 24' travel trailer isn't super heavy so you'd probably be okay but if the budget can at all fit, you'll be far happier and better set up for future (bigger?) trailers.
Your post really touches on the two different but often muddied towing factors - carrying and pulling. The 5.7 8spd in the 1500 is a powerhouse for pulling but the 1500 suspension is mushy. The 5.7 6spd 2500 is stout to carry the weight but definitely inferior pulling. 2500 8spd is the best of both. Having to choose one I'd go with what you're thinking of and having a 2500 platform to carry the weight and be bit slower.
Are you using a WDH and is it set up properly for the four corner air suspension?
Just because it's level doesn't mean it's correct.
Hagar1
Ontario Canada
2012 Ram 1500
You will need 2 trailer hitches, 1 for your trailer and the other for the gas station you need to bring along!
joesstripclub
Kansas City, MO
2021 2500 PW
^^This
Are 5.7 2500s old enough to be leaf springs still? That would be the only down side I see to a 6.4 2500 with the 8 speed is the coil springs. Still plenty capable but a little mushy at heavy loads.
mtofell
IIRC, they are leafs.... great point/question. I think that was one of the upsides to the 6.4 when it came out. Also, I believe the 5.7s only have a 9,000 GVWR compared to the 10K on the 6.4. I'm sure the axle weights total far more than the 9K but that's a whole other story/debate.
stembridge
The Middle South
Pentastar 3.6
I owned a '15 2500 4x4 Tradesman with the 5.7/6sp./3.73 and it pulled fine, albeit at around 8-10 MPG depending on load and weather. Unladen MPG was usually around 13-14.
The 6sp. transmission programming is horrid. I hit Tow/Haul every time I started up, whether towing or not.
I retired and moved South in 2020, and bought the above 25' enclosed trailer to make the move. Seven trips, all loaded to the gills. Driving into a headwind for 10 hours on one of the trips, I was making about 6MPG. Prior to the move, I hauled hay and livestock with a gooseneck trailer.
She pulled my tractors fine, too.
I've since sold the truck and replaced with a '21 Classic QC 3.6, as I no longer needed a farm truck. Wife always complained about the harsh ride in the 2500, and wanted a second row for outings with the grandkids.
SeventyGTX
SeventyGTX
Yes it does have a WDH, although it came with the trailer and the guy I bought it from had a truck very similar to mine but without air suspension so have just used it as is. I get zero sway with it, but i probably should have it all weighed to know exactly where I'm at.
WDH needs to be set up for the load, there have been countless people posting about issues towing trailers and they stated the RV place set up the WDH. A trailer's weight (tongue and total) along with hitch height can all effect how the WDH works.
Trailer sway is due mostly to a poorly weighted trailer, truck wallowing is usually from poor weight distribution. I'm guessing the air suspension was hiding the rear end of the truck being too heavy. On an air suspension truck that also makes the front axle softer in an attempt to level the vehicle out.
There directions in the owners manual how to set the air suspension so the WDH can be properly adjusted.
SeventyGTX
SeventyGTX
Outside of the soft feeling, I have no other issues, so not sure if adjusting it any will help much. But it won't hurt to try. I just miss my 2500 and 5th wheel w/Anderson hitch. Easy hookup and great ride. Maybe someday I will get back into a similar setup as that.
RidingwithRanger
