Audio guys...Help?
88ROOK
illinois
so i purchased another amp, already had jl xd700 so i added another. my question is can i just run an RCA splitter off each channel off the DSR because im going to bridge each amp to get max power to fronts and rears. OR do i have to purchase another DSR to run another amp.. never done this DSR factory stuff before, only radio-amp-speakers (simple)
Eestee70
Chicago
What are you trying to accomplish.How many speakers are in your system now, and how many more are you trying to add?
adurm
FL
2015 RCSB
Isn't there a switch on the jl that would split the 2 ch input to feed all channels on the amp?
Eestee70
Chicago
I may by wrong but I think what 88ROOK is trying to do is make the DSR1 that has 8 channels of output into a 10 channels by splitting two channels on the DSR1. The JL XD 700/5 amp is 5 channels. add another =10 channels
adurm
FL
2015 RCSB
Whoa. That's alot of channels. Should have figured it wasn't so simple. Thought he was trying to run the 5 channel off 2 ins. Gotta learn to read more better.
88ROOK
88ROOK
illinois
i want to know if you can run 2, 5 channel amps off of 1 DSR( rockford fosgate). if i bridge the amps one amp will run the fronts and a sub and the other amp will run the rears and a sub
Eestee70
Chicago
It’s possible.....I can see what you’re trying to do. Here’s an example.
Let me know is this is similar to your plan.
Amp 1:
Channels 1/2 bridged @ 150 Watts l/f speaker.
Channels 3/4 bridged @ 150 Watts r/f speaker
Channels 5/6 for left sub.
Amp 2:
Channels 1/2 bridged @ 150 Watts l/r speaker
Channels 3/4 bridged @ 150 Watts r/r speaker
Channels 5/6 for right sub. You will be turning two channels into one, so your DSR unit may not recognize that which can lead to tuning issues. It’s possible that you could mute one of the channels on the DSR for each channel bridged to avoid tuning problems. Just a possibility......but don’t know if that will actually work. Contact Rockford Fosgate. I’m sure they’ll know for sure. Good luck.
88ROOK
88ROOK
illinois
So I talked with the fosgate tech support on my issue. they said i could def. run a "Y" spitter to run multiple amps with no issue. So this good news for people wanting to run a multiple amp setup with the DSR1
Eestee70
Chicago
Cool. I have a thread for showcasing audio builds, search audio project and post your equipment if you don’t mind
88ROOK
88ROOK
illinois
I dont have any pics at the moment, but I'm running JL C2 350x dash, JL TR690 TXI in the doors, 2 JL 10WO v3 subs, fosgate DSR1.........side note: I have 2 pairs of perfect condition JL Audio C2 570X (5x7) for sale if anyone is interested. OR if someone would like to trade for a pair of C2 650X (6.5s) , I'd being willing to trade both pairs for 1, just so i have them if i dont like the 6x9s up front
GPRADA
