Audio problems.
suzukiquadrider
cummins 5.9, 6.6 duramax
I am at my witt's end. as some of you may know i blew a 6x9 in my front door and my deck stopped reading CDs, so i purchased a new pioneer 33hd head unit and some 150 dollar kicker component speakers. I wire everything up according to the wiring manual, the deck powers on but no SOUND, i try, ipod, cd, radio, no sound!! so i rip everything apart rewire it all back together, still nothing!! I figured i would take the doors apart, i am drilling one of the mounting screws into the bracket to hold one of the component speakers, a screw slips and my drill slams into my speaker making a huge gash in it........there goes 150 bucks......glad i make minimum wage.............What on earth could be wrong with my system? and what can i do with one component speaker, i honestly i am so pissed that one small screw slipping causes me 20 hours of work i have been saving up for 2 months.
so mainly my 2 questions are, What am i missing? i have the infinity audio system and my deck will power on but not a peep is coming from my system and what do i do about that door speaker as i wont be able to afford another set for at least 2-3 more months....
End rant.
Also where do i run lines to my battary? like a sub wiring kit where do i run the wires? is there a nice convenient place to run them?
02hairlessram
Have you tried hooking a speaker to just the head unit with out running through factory wiring. May have a bad head unit. And for the messed up speaker, did you order offline or through a local audio seller? I would try to return them, tthe worst they can say is no.
David
suzukiquadrider
suzukiquadrider
David
Bought them from crutch-field, it was my own stupid falt for braking the speaker. i tried hooking up the head unit to just a 6.5 with no luck. So the head unit could be DOA, or is the infinity system in the rams funky? does it require different wiring?
huntram03
Cincinnati Oh
6.7L CUMMINS
^^^ that and check the setting on the unit.. may sound crazy but some units have a mute and you could call Pioneer they do have pretty good teck support to walk you through trouble shooting.. good luck!
huntram03
Cincinnati Oh
6.7L CUMMINS
also did you get the harness from factory to aftermarket or did you cut and crimp wires?
suzukiquadrider
suzukiquadrider
i checked the mute, it still wont play, i sodered the wires, so custom cut and crimp job. but the strange thing is, the unit powers up just fine, but no sound not even static is released from any of the working speakers, it is like something with the speaker wiring is totally messed up.
huntram03
Cincinnati Oh
6.7L CUMMINS
oh ok.. you could have wires crossed somewhere.. I would call crutchfield first see what they have to say, if they wont help then my next call would be to pioneer. Also I would suggest rewiring the factory plug and go to walmart and get the harness adapter for it.. I know you said money is tight but that is what I would do.. Make the calls and see if they can help first then go from there..
suzukiquadrider
suzukiquadrider
kk ill make the calls tomorrow, i took all of the electrical tape off and verified every connection was color matched, i made sure the ground was grounded, no wires were touching, i got the wiring harnesses from crutch field but it was 2 of them that needed to be sodered together.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Ryan,
Install slips happen bro, what midrange did you rip into? I will see if i can help.
suzukiquadrider
suzukiquadrider
Ryan,
a drill with a philips head ripped into the speaker and basically killed it.
Ok another question
Where do i run a line to my battery? where is a good place to run a wiring kit for subs? is there a set up location for them? is where a place where the clutch used to be?
thanks
huntram03
Cincinnati Oh
6.7L CUMMINS
So im guessing that you have sound now? If so what was the problem?
suzukiquadrider
suzukiquadrider
ground wire was miscolored, called crutch field and pioneer, it was blue not black. caused everything to be messed. not happy with pioneer quality.
know of any where to run a line to the battery?
huntram03
Cincinnati Oh
6.7L CUMMINS
not off the top of my head but when i get off work and get home i will look for a good spot on mine.. they should be close to the same..
jamestaylor47
OKIE
I ran mine through a little rubber hole right below the steering column and up into the battery sounds crazy but it worked for me and I haven't had any other problems with it yet.
[Tap tappin]
HemiBabe
DFW
Mine goes under the kickplate sill by the door and thru the little grommit into the engine bay
Jantelaw
