Backup Cam. Use DD Reverse wire or Trailer Harness
mxblaster83
British Columbia, Canada
2014 Ram Sport
HEMI 5.7
should i use the reversve wire off my DDX790 or just use the trailer harness if so what color is it.
ive heard that using the trailer can sometimes underpower the backup cam
SIhemi
Pennslvanvia
I used the wire going to the reverse light. Don't have a problem with it. It only goes on in reverse.
jlb
MT
CTD
I used the trailer harness with no problems.
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
do you recall the color of wire? also did you run the video cable up through the motor bay into the clutch grommet i already have a holr there for my amp power wire
SIhemi
Pennslvanvia
There's a rubber grommet under the drivers side door sill. The transmission cable runs through it already so I bad the hole a little bigger to push the wire through. Than I sealed it with some silicone.
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
do you remember the color of wire you tappped into? also did you use the trailer ground too or just ground off the frame?
SIhemi
Pennslvanvia
I tapped into the reveres wire not the trailer wire
baum
savage, mn
2015 Laramie
i also grounded it at the trailer harness.
on a side note. the reverse wire on the ddx is an input NOT an output meaning this should also be hooked up to the reverse lights. when this wire gets triggered with the reverse lights it cuts off all other video/graphics on the ddx and put on the reverse cam.
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
so would i just tap the reverse wire off the ddx to the harness from the truck?
is it the same color?
jlb
MT
CTD
For running into the cab I trimmed the big rubber nipple that sticks out of the firewall in the same region as the stock harness passes throguh. I have a bunch of extra wires running into my cab for various, and sundry things, so I needed more space than I could find in existing openings.
baum
savage, mn
2015 Laramie
what harness/module did you buy to connect the radio to the factory harness?
if you only have a basic harness then yes run the reverse light input wire from the ddx to the reverse light wire of the car.
there are many posts on here about obtaining factory wire colors you simply put in your VIN and it tells you locations/colors.
mxblaster83
mxblaster83
2014 Ram Sport
HEMI 5.7
i dunno what harneess i got, all i see is the purple wire from ddx saying reverse wire.
baum
savage, mn
2015 Laramie
thats the input to the radio to switch the video to the cam when you have it hooked up
Steve58
