Battery Disconnect
Stephen Yale
Katy ,TX
I disconnected the battery prior to a throttle body clean. I took the throttle body out and cleaned it, wasn't that dirty. I reconnected the battery. Then...
Uconnect
When I selected reverse my backup camera never came on
AC, in auto, will only let me select HI or LO no temperature in between
There may be other things too that I have not discovered but these are alarming enough.
How do I reset these tings to factory on Uconnect so I have a backup camera and control of the air conditioning ( I am in Texas and temp outside is 93 degF without heat index)
Stephen
Sometimes it takes a few Key Cycles to make things return to normal
Try driving your vehicle normally for a day or two
Dodge 1500 4X4
Rochester, NY
Make sure you Sync your climate control, Its on the climate control screen right side.
