Another Build sheet questions..
17Veteran76
Georgia
Just bought my ram about a month ago. Have been looking to see exactly what she has. Found the build sheet vin decoder and now have some questions I couldn't find answers to through the search, or were not clear to me. Some of my confusion I believe is in Dodges/Rams terminology, where as I believe it calls standard equipment "Heavy Duty". Where someone like me would be lead to believe the HD means its improved over standard "light duty" equipment. As well as oil/transmission coolers which usually only comes on tow packages seem to be standard on rams and again called "heavy duty".
Any input would be helpful.
Vehicle Description
2017 RAM 1500 SLT 4X2
Monotone Paint
160 Amp Alternator
730 Amp Maintenance Free Battery
Electronic Stability Control
Anti-Lock 4-Wheel Disc Brakes
Prem Vinyl Door Trim w/Map Pocket
2nd Row In Floor Storage Bins
Front Height Adjust Shoulder Belts
Supplemental Side Air Bags
Advanced Multistage Front Air Bags
Supplemental Frt Seat Side Air Bags
Carpet Floor Covering
Driver/Passenger Assist Handles
Rear Underseat Compartment Storage
3.21 Rear Axle Ratio
235MM REAR AXLE <- What does this mean exactly?
Conventional Differential Rear Axle
Tinted Glass Windows
Tinted Windshield Glass
Rear Power Sliding Window
Remote Keyless Entry with All-Secure
Sentry Key Theft Deterrent System
Dash Liner Insulation
STANDARD EQUIPMENT
Floor Tunnel Insulation
Instr. Panel Color Keyed Bezel
120 MPH Primary Speedometer
Temperature & Compass Gauge
Var Intermittent Windshield Wipers
Dual Note Electric Horns
12V Auxiliary Power Outlet
Power Accessory Delay
Power Locks
Pwr Front Windows, 1-Touch,Up & Down
Front Passenger Seat Belt Alert
Vehicle Information Center
Incandescent Taillamps
Traveler/Mini Trip Computer
Halogen Quad Headlamps
Automatic Headlamps
Cargo and CHMSL Lamp
Bright Rear Bumper
Body Color Upper Fascia
Bright Front Bumper
Front License Plate Bracket
Front Wheel Spats
Ram's Head Badge
Rear Wheel Well Liners
Body Color/Chrome Door Handles
B-Pillar Black out
Rear Wheel Spats
Ram 1500 Badge
Front Bumper Sight Shields <- What is this?
26 Gallon Fuel Tank
Speed Control
Maximum Steel Met. Clear Coat
6 Speakers
Power Rack and Pinion Steering
Front Heavy Duty Shock Absorbers <- All 1500's come with "HD shocks" rather than it being for towing?
Rear Heavy Duty Shock Absorbers <- All 1500's come with "HD shocks" rather than it being for towing?
Front Stabilizer Bar
Rear Stabilizer Bar
Tilt Steering Column
Tire Carrier Winch
Non Adjustable Pedals
Pickup Box
R1234YF A/C Refrigerant
7 Pin Wiring Harness
Trailer Tow w/4-Pin Connector Wiring
Locking Tailgate
Body Color Fuel Filler Door
'Why Buy' Label
English/USA Language
Seat Parts Module <- These module listings are what control the parts?
Instrument Panel Parts Module
Door Parts Module
Front End Parts Module
Tire & Wheel Parts Module
Build To U.S. Mkt. Specifications
U.S. Dealer Retail
Zone 66-Orlando
Crew Cab
DS/6322 Vehicle Family
Two Wheel Drive (2WD)/(4X2)
2017 Vehicle Specifications
Price Class H - SLT
5 FT. Cargo Box
1500 Series
Vehicle Order Tracking
U.S. Specifications Label
Georgia Ship to State Code
Georgia Sold to State Code
Cloth 40/20/40 Prem Bench Seat
Black/Diesel Gray
Big Horn Regional Package
40/20/40 Split Bench Seat
Front Armrest w/Three Cupholders
Supp. Side Curtain Frt/Rr Air Bags
Front & Rear Rubber Floor Mats
Rear 60/40 Split Folding Seat
Storage Tray
Front Center Seat Cushion Storage
Folding Flat Load Floor Storage
Overhead Console w/Garage Dr Opener
Rotary Shifter-Black
All Automatic Transmissions
8-Spd Auto 8HP70 Trans (Buy-US)
5.7L V8 HEMI MDS VVT Engine
Sun Visors w/Illum Vanity Mirrors
OPTIONAL EQUIPMENT
Rear View Auto Dim Mirror
Auto Dim Exterior Mirror
Power Heated Mirrors, Fold-Away
All Vehicles W/Power Mirrors
Air Cond ATC w/Dual Zone Control
Electroluminescent Instr Cluster
115V Auxiliary Power Outlet
NAV-Capable! See Dealer for Details
GPS Antenna Input
Power Lumbar Adjust
Power 10-Way Driver Seat
Glove Box Lamp
Underhood Lamp
Ext. Mirrors w/Supplemental Signals
Exterior Mirrors Courtesy Lamps
Power-Folding Mirrors
Black Exterior Mirrors
Rear Dome w/On/Off Switch Lamp
Fog Lamps
LED Bed Lighting
Security Alarm
Active Grille Shutters <- What are these exactly?
Bright/Bright Billets Grille
Hemi Badge
Big Horn Badge
50 State Emissions
Dual Rear Exhaust w/Bright Tips
Heavy Duty Transmission Oil Cooler <- This is standard on all 1500's? Do I need to add something bigger for towing?
Engine Oil Heat Exchanger <- This is standard on all 1500's? Do I need to add something bigger for towing?
Exterior Mirrors w/Heating Element
Electronically Controlled Throttle
Heavy Duty Engine Cooling
Next Generation Engine Controller
All Radio Equipped Vehicles
Uconnect 3C with 8.4" Display
Fixed Long Mast Antenna
Steering Wheel Mounted Audio Ctrls
8.4" Touchscreen Display
SiriusXM Satellite Radio
Audio Jack Input for Mobile Devices
Remote USB Port
Remote USB Port - Charge Only
Media Hub (USB, Aux)
Uconnect Access
All VP3 Radios
Leather Wrapped Steering Wheel
Full Size Temporary Use Spare Tire <- I have 20" tires with a 17" spare, should I ask the dealer to provide a 20" spare as well. I would think 3" would have quite the lean...
P275/60R20 BSW All Season Tires
Goodyear Brand Tires
20X8.0 Aluminum Chrome Clad Wheels
All Aluminum Wheels
Center Hub
17" Steel Spare Wheel <- As pointed out above...
ParkView Rear Back-up Camera
ParkSense FT/RR Park Assist System
Remote Start System
Tip Start
Vendor Painted Cargo Box <- What is this?
Class IV Receiver Hitch
Universal Garage Door Opener
Tire Pressure Monitoring Display
Integrated Voice Command w/Bluetooth
Humidity Sensor
Electronic Shift
Raised Ride Height
1-Yr. SiriusXM Radio Service
For Details, Visit DriveUconnect.com
For More Info, Call 800-643-2112
6 Mo. Trial (Registration Required)
5 Additional Gallons of Gas <- Which makes my 26 gallon a 31 gallon (32?)?
Spring - Left Front
Spring - Left Rear
Spring - Right Front
Spring - Right Rear
GVW Rating - 6900#
Customer Preferred Package 2TS
Customer Preferred Package 26S
6 Month Trial (Reg. Required)
Group Discount
Sales Tracking
Vendor Painted Cargo Box Tracking <- What?
Saltillo Truck Assembly Plant
Easy Order
Priority Tracking
United States Region Group
NAFTA Regi
ColdCase
235MM REAR AXLE <- What does this mean exactly? ...Thats the size of the ring gear in the diff.
Active Grille Shutters <- What are these exactly? ....Thats shutters in front of the radiator that close in cold weather and during warm ups so the engine warms up faster and runs warmer (emissions).
Full Size Temporary Use Spare Tire <- I have 20" tires with a 17" spare, should I ask the dealer to provide a 20" spare as well. I would think 3" would have quite the lean. .... The spare tire has overall the same diameter as the road wheels/tires regardless of wheel size. You need to look at tire size not wheel size. A 20 in wheel could have tires with 10 inches of sidewall giving you 30 inches overall where a 17 in wheel would have 13 inches in sidewall giving you the same 30 inches in diameter.
Vendor Painted Cargo Box <- What is this? ... they sent is off site to have the cargo box painted probably the sprayed in liner.
5 Additional Gallons of Gas <- Which makes my 26 gallon a 31 gallon (32?)? ... FCA puts 5 gallons of gas in the tank.
Vendor Painted Cargo Box Tracking <- What? .... this is the tracking number of the truck through the off site process.
You have the tow package (receiver tell tale), so the HD things you listed are include with the tow package. I think all RAMS with your trim have trailer tow.
Door Parts Module
Tire & Wheel Parts Module... these are bags of stuff like brackets, harnesses, bolts, and modules that are installed in the production line.
17Veteran76
17Veteran76
Georgia
Damn, that was fast. I appreciate that. I guess I'll buy the OEM electric brake controller and install it. Was thinking about getting a camper, now I know...
911ems
Toledo OH
My build sheet looks nearly identical to yours. I added the oem brake controller and tow mirrors for pulling our camper. It does great, including the 3.21 gears.
17Veteran76
17Veteran76
Georgia
Thays what I plan. To get next the OEM brake controller.
Sent from my VS988 using Tapatalk
jimn
